I own a 3HP fixed base PC router for use soley in my table. I am concerned that dust and chips are finding their way into the router though the fan exhaust. I have thought of using a plate to cover but I think that will cause more damage with overheating. What do you do? Am I worrying about nothing?
Newer pressure treatments don't offer the same rot and decay resistance. Follow these simple strategies to give outdoor lumber its best chance of survival.
SawStop's Portable Tablesaw is Bigger and Better Than BeforeRelated Stories
Do you have a dust collection system attatched to your fence? That helps. I have several melamine bases for my router. I use the base with the smallest hole that still clears the bit I intend to use.
*Yes.
*Don't worry about it, just vacuum it out occasionally. My PC 7518 has been in my table for a long time now. When I pull it to change bits, etc, I vacuum it out. The turbulence from the motor keeps the fine stuff out and that's what you would need to be worried about.
*I just blow mine out with compressed air when im done. I first hold and blow it out turning it slowly by hand then I turn it on and blow it out again. over kill maybe but it works for me. In fact I gotta do it again in about 3 hours after the paint dries on the doors I made.
