RTD PLYWOOD
Jake0358 | Posted in General Discussion on May 6, 2009 03:14am
Home Depot has “RTD” plywood. Does anyone know what “RTD”
means, and is it somehow different from any other plywood?
It is just that I like to know about the products that I’m working with.
By the way, when asked what “RTD” meant at HD, they really didn’t
have an answer. Hopefully someone here will.
  1. Shep | May 06, 2009 03:15pm | #1
    "Ready To Delaminate"?
      IMERC | May 06, 2009 03:29pm | #2
      is that better than the ARD (already delaminated) ply from there????
      WOW!!! What a Ride!
    2. MikeHennessy | May 06, 2009 04:39pm | #4
      LOL! You win!Mike HennessyPittsburgh, PAEverything fits, until you put glue on it.
    3. Jake0358 | May 06, 2009 06:14pm | #6
      Shep,One of my workers said it stood for "Return To Depot"I thought that was a good one as well.
      SteveInCleveland | May 06, 2009 06:22pm | #8
      I think they stock it next to the ABC gum.
      "Preach the Gospel at all times; if necessary, use words."  - St. Francis of Assisi
      No, I didn't vote for him; but he IS my president.  I pray for the his safety, and the safety of his family every day.  And I pray that he makes wise decisions.
    Sphere | May 06, 2009 03:36pm | #3
    There has been a lot of issues with delam. from temperature variances in maunfacturing. The RTD is better quality monitoring of the  glue used in the presses.
    The glues cure by RF ( radio freq.) and/or steam and need to reach the optimum temp to react properly. RTD is a way adding quality control to the process.
    "The use of the in-process RTD sensors significantly reduced the delamination caused by insufficient heating of the plywood during the press cycle. If the plywood sheet is found to have delaminated areas, it is sold as a lower grade plywood at a reduced market value. Each press handles 30 sheets of plywood per two-minute press cycle, so the reduction in delamination has significant economic impact."
    "If Brains was lard, you couldn't grease much of a pan"
    Jed Clampitt
    Edited 5/6/2009 8:38 am ET by Sphere
    Edited 5/6/2009 8:40 am ET by Sphere
    1. Jake0358 | May 06, 2009 06:11pm | #5
      Sphere,Thanks for the info. I appreciate it.
  3. KenHill3 | May 06, 2009 06:14pm | #7
    Ready To Delaminate. What a hoot. Definite winner.
    I'll add my own (lame by comparison to Shep's) version:
    RTD: ReTurneD
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
