What would cause my 1 year old american standard toilet to constantly run? I do not see any wanter height adjust like on older models so how do I get it to stop?
![](https://images.finehomebuilding.com/app/uploads/2024/08/15131650/FHB-645-Pod-Feature-thumb-16x9.jpg)
Listeners write in about condensing dryers, giant gears, and saggy doors and ask questions about chimney safety, black windows, and rot-resistant assemblies.
There should be a stainless clip on the flapper rod that adjusts water height.
Scott.
Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.”
Basically 4 reasons:
1) Defective unit. There can be a flaw in the tank casting or in the overflow tube that allows water to continuously leak out around the flush valve.
2) Flush valve not sealing tightly.
3) Water level too high, causing water to go down the overflow tube.
4) Siphoning from the tank through the bowl fill tube. If the end of the tube is shoved too far down the overflow tube, it causes a siphon to occur.
put a new flapper on it
I don't think it's going to do any good unless you put the flapper IN it.
legs...
WOW!!! What a Ride!
yer post went through first cuz yer closer to Chicago,,,lol
"Even if embryonic stem cells are absolutely good for nothing at all how can anyone in good conscience be against using them for research given that they are going to be destroyed anyway"? J.Hayes
http://www.john-lennon.com/imagine-neilyoung.ra
it was because of the air card....
airmailed it.....Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
What would cause my 1 year old american standard toilet to constantly run?<<
Reckon it depends on who's sittin on it...BWAHAHAHAHA
or who's about to sit on it...
it's just trying to get out of the way...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
