I have a couple of Record brand block planes made in England that I cannot store like Stanleys and other hand tools. I’ve taken to coating the Records with thin layer of grease to try and prevent rust from forming but is real pain in the butt to clean them before use. Have tried a couple brands of rust preventative but none works real well and last night I was again going over planes with fine grit wet/dry to remove rust from numerous spots. Some areas are already slightly pitted and it is maddening. Must be something with the type of steel. I’ve not contacted Record yet. Hopefully I’ll find the answer here
Randy
Randy- Perhaps storage in plastic totes or ammo boxes, with the addition of a dessicant like silica gel? -Ken
*Simple, just like with a table saw, use Johnsons Paste Wax. Steve
*randy- try this method a little wierd but i use it and it works. take a sock athick one prefer, fill it 1/3 to 1/2 with rice, you can put a very thin coat of paste wax. and i think you've cinched your problem. cheers
*I use Bostich B9 spray. it is a penetrating wax.
*pif- Is that the Boesheild? -Ken
*Paste wax works for me. Just remember to re-apply every once in a while.
I use Rennaisance Wax. It works great on all my tools stored out in the garage. It's expensive but well worth it.When people 100 years from now see my work, they'll know I cared. --Matt Mulka
Yeah, that's right. Musta been asleep at the switch when I posted that one back in the old board and just now getting caught up. I used it on my table saw top too. It is also good for my trim circular saw footplate to keep it sliding neat without dragging dirt marks on good wood.
Any way I work within a stones throw of the Atlantic Ocean most of the time and my seven year old Tablesaw top is only just now starting to show a brown colouring. But then I haven't used it so much this year.Excellence is its own reward!
I feel your pain. Being in a warm and rainy environment rust is a constant problem for myself also. I have had some luck using paste wax and sealed tool boxes, ammo cans and tight plastic units. The addition of a vapor deposition pad to each box has turned the tide. Now I only find rust after I work in the rain and don't properly put the tools away. The pads are available at:
http://www.senson.com.au/tdata/vapaguard_pads.htm
I find that the P2 model works well for the size of my tool boxes. You will have to size the pad/s for the internal volume of your tool box and adjust for how often you open them. I hope this helps.
Lie-Nielsen has a silicon(e) treated cloth sock for storing planes that is supposed to help keep rust at bay. Just got one and will see how it works.
http://www.lie-nielsen.com/tool.html?id=PS-Small&cart=102002174851293
