Why don’t they make the condensor coils out of something more mositure resistant? Yeah, I know…COST!
Have another one that rusted out and is costing some money to fix. Its only 9 years old too.
Learning more about accommodating neurodivergence in the trades can help grow a much-needed workforce.
maybe it isn't rust...
maybe you have someof that chinese drywall...
WOW!!! What a Ride!
Drywall outside?
the coil sat inside for awhile and then was moved outside..
WOW!!! What a Ride!
Most AC condenser coils are made from aluminum (a few, I suppose, from copper). The coils themselves should not "rust" (though they will oxidize and corrode). Generally the immediate supports will be of the same material (to avoid galvanic damage), but obviously the condenser housing is typically steel.
Any decent AC condenser should last over 20 years exposed to "normal" conditions, and 30 years is not unlikely. If you've got them corroding through in 9 years then something else is at work. The lifetime of the housing depends a bit more on the quality of the unit, but even if badly rusted structural integrity should not be impaired for 20-30 years.
In the 90s Carrier had a whole bunch of coils fail usually at 6 to 9 years or so. Many of my neighbors had that problem, course the HVAc reps then sold them a whole new unit. No help from Carrier
It's the alt in the air in Florida.
When I lived there I remember the number of radiator shops, never had seen so many. Moved back to NY, lucky to have one in a town. Got to be that salt air!!
I had a condo on the beach and I agree, salt will kill the case, but the condenser coil itself usually lasts 15-20 years.
We had several on the roof that were still blowing cool air inside and the compressor was just hanging from the copper, laying in the hot mop pad. The case under it had pretty much rusted away. The condenser fan was banging and making a racket that got us up there for a look.
