safety apron
bbober | Posted in General Discussion on January 26, 2004 03:42am
I have a Unisaw which has a great deal of power.  I was cutting some 0.25 inch plastic and had a piece fly back and hit me in the leg.  I still have the scar.  It could have been a lot worse.
I am looking for a heavy duty leather apron to protect me.  Can anyone suggest a source?  Does anyone wear a similar precaution?
    Sphere | Jan 26, 2004 05:05pm | #1
    check under 'farrier supplies' local farm store or google, bestest tough leather.
    Go Stab yourself Ya Putz! Ya think I Parked here?
    NickNukeEm | Jan 26, 2004 05:46pm | #2
    Welding supply?  They use tough leather to weld in.
    If you want to go the medieval route, try chain mail.  Don't let the weight get you down, though.
  3. VaTom | Jan 26, 2004 06:58pm | #3
    Ummm... why did you get a piece of plastic flying at you?  If the fence is adjusted properly, the right blade, and you're feeding correctly, you shouldn't have had a problem.  If it was a miter guage, you should have been using a sled.  One nice thing about a Unisaw is they don't have much vibration.  My last employer had a ¼" sheet of plywood come flying at him.  Scared the crap out of him, but it wasn't the saw's fault.
    Only time I use armor is when I put something unstable in my lathe, knowing I'm taking a risk.
      NickNukeEm | Jan 26, 2004 07:33pm | #4
      Good point.  Every once in a while, though, when you least expect it...
      When my son wanted to work in the shop around the tools (not with them, that was a few years down the road) I set up a demonstration.  With the table saw running and both of us off to the side, I tossed a scrap on the spinning blade.  It shot across the shop, gouged beyond belief.  Sonny's eyes were WIDE when he saw the scrap.  He still wants nothing to do with the table saw, or radial arm.  Works on the band saw all day, though.  Had to tell him I saw a guy cut his thumb off on a bandsaw, not watching where his fingers were when the blade passed through the edge of the wood.
      Being alert and using some common sense should prevail.  But a good helping of respect is always a good thing.
        RichBeckman | Jan 28, 2004 07:04am | #5
        At the lumberyard I buy from they have a nice shop. The tablesaw is positioned about twelve feet from an exterior door which is usually open. A good fifteen or twenty feet from the door is another building with steel siding. The steel has clearly been hit hard on more than one occasion.
        Don't stand in the doorway while something is being cut.
        Rich Beckman
        Another day, another tool.
  4. mikerooney | Jan 28, 2004 07:31am | #6
    Kevlar.
    briankeith | Jan 28, 2004 08:15am | #7
    found one on Amazon
    http://www.amazon.com/exec/obidos/tg/detail/-/B0000DCZPF/qid=1075266645/sr=1-11/ref=sr_1_11/103-7203242-0999004?v=glance&s=hi
    But then I checked eBay
    Check that out, just search for "leather apron"
    there were a lot and at very good prices. $10 or less
    1. cso | Jan 28, 2004 08:54am | #8
      How about a pair of chaps from the western store. heh heh.
  6. r_ignacki | Jan 29, 2004 02:37am | #9
    meat cutting supply house will set you up with a mesh apron. aka chastity belts.
    sure will save you from a stab wound in the middle leg cutting up that roadkill.
Mortar for Old Masonry
