What is the recommended grit for sand blasting paint off of stucco? The rental guys rent them, but they don’t know what grit to use. Does any body know?
How much paint is on the stucco ? If you have a lot of coats you will remove stucco in order to get the paint off . The paint acts like rubber . If you only have a light coating of paint just about any grit will work so get what will be cheapest by the ton.I use U.S. Silica #14 because the smaller #15 leaks out of my hopper. This will be a one time shot do not reuse the sand,it is cheap so use the smallest grit ,usually the cheapest per ton , if you don't have a lot of paint . The smaller grit gives a better finnish . Larger grit cuts more aggressive usually cost more.
It looks like there is only one, well applied coat of paint on the stucco. Do you have a "ballpark" formula for how much sand per square foot of wall. I will be doing this on Sat/Sun and I want to make sure I have enough material and preferably not too much. I will be blasting about 75 lineal feet X 8 feet high(600 sq ft ) plus maybe I'll blast of the driveway in front of my shop. Hope to get rid of overspray and other guk from 7 years of finishing cabinetry and auto work.
Thanks for your help. -Brian
Are you going to repaint? If so you donot have to get all of the paint off. Just the "loose" stuff . I think that guk infront of the garage will not disapear all that easy. I would hate to give a guestimate on the amount of sand for tha wall . If it were steel I would say that you should be able to get it done with 500 to a 1000 lb. I spent about 6 hr. and 2ton of sand trying to clean up a cement block spray booth . I had to acually blast the cement awy from under the paint to get it off the wall. However that was an extreme because it was more than 1/8" thick.
The other thing is there is a learning curve . If you had done this before it would be quicker . Make sure that you get the hard plastic helmet /with incoming air. Ductape the sides of the lens so that light does not shine in the sides. then ductape a strip over the top or bottom of the lens, make tabsby sticking the tape to itself 1/4"orso , so that you can pull it of and reposition it over the eched part of the lens. This will make it easier to see what you are doing . If you are in the dark it is easier to see the light .
Get the big compressor , at least 175 cfm . Don't try to do this with your 5hp. sears compressor.
At 100psi a 1/4" nozzle will use 490lb. sand at 137cfm. I have a formula for sand /sq.ft. some place but have never found it to beremotely close ,way over on there estimate.
Don, thanks for your reply. I finished the sand blasting yesterday and every thing went as plan except that I should have bought twelve 100lb bags of silica sand not ten. At $6.50 a bag it was cheaper and faster to have my 17yr old son run the waste sand through my wife's baking sieve than go out a buy more. Plus I would have had to pay more for the rental of the compressor and blaster. When my wife found out what I used, did she ever give me the "stink eye". Thanks. -Brian
Yep I know what you mean. Them wimon don't like to share tools no how. But keep the chisels hid or they will become feminine prybars.
Glad the blasting turned out .
Don
