Has anyone used the sand & kleen product for dustless drywall sanding? I have a potential job, homeowner was worried about the dust and I thought that this was a cheapest product out there to get me through this job. Any reviews of this product??
In this FHB Podcast segment, the crew offers expert advice on insulating an old home and finding the right contractor to do the job.
I was going to write a post inquiring about this tool myself.
I bought one about three weeks ago. It is a work out. I have it hooked up to a 16 gal shop vac, and even with all the "air bleeders" open, it was a push and pull battle. The other thing I didn't like - the use of sanding screens. The screens left scracthes (even with 220 grit) probably from the strong suction. I ended up hooking it up to my Random orbit sanders exhaust - worked ok.
The Sand and Kleen when used with the sanding screens pulled almost all of the dust, but I had to go back and sand the scratches.
My verdict is still out - I think with some modifications it would be a good tool. When final note of caution: the bucket will have quite a static build up (enough that you will hear crackling when you shut the shop vac off). When you go to change the water, you'll get a few zaps. I didn't ground the bucket, but it might a good idea.
