sandstone water reactive?
ycsifmh | Posted in General Discussion on July 21, 2008 04:38am
Installing “Pietra Serena” sandstone tiles using the wet-set method (pounding them into a floor mix with a splash of neat on top).  The tiles vary in size from 12″x24″ to 36″x36″ all are approx 3/4″ thick.
Two strange things:
First I found that as I’m pounding them into the wetbed, I could bend the corners enough that they would spring back and pullaway from the mortar when I released pressure.  Easy enough to deal with once you realize its happening
Secondly, though, I found that the larger units would cup, as much as 1/8″, once set.
I have seen this with green and black marble, but never heard of sandstone doing this.
Do I need new glasses?
Thanx
  1. rez | Aug 01, 2008 06:58pm | #1
    Greetings ycsifmh,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    Click here for access to the Woodshed Tavern
    Click here to visit the beginning of Breaktime
    McDesign | Aug 02, 2008 01:36am | #2
    Common mistake - you got the quicksandstone.
    Forrest - no idea
  3. rez | Aug 13, 2008 12:19am | #3
    http://www.johnbridge.com/vbulletin/index.php
    is a link to a popular tile site that may be able to provide you with some data.
    cheers
