Can anyone refer me to a source for sash-weight pulleys? I’ve come back empty-handed from our local architectural salvage companies, and the only source I can find online is located in England.
![](https://images.finehomebuilding.com/app/uploads/2024/07/10133441/01232535-cali-valley-heads-east-feature-Large-thumb-16x9.jpeg)
Construct the intersecting gable on the main roof for a faster, easier-to-build assembly.
where are you at in the world, in san francisco i can think of several places to find what you are looking for, ocean sash and door on 17th and south van ness is one, as far as internet i no of not one.
*Try Phelps or Architectural Resource Center, both of which have links at http://www.traditionalbuilding.comThey both definitely have pulley, but they are relatively expensive. There may be a few other places listed there for window hardware.If you only need a pair, you might want to try eBay at architectural hardware. Amazing what people are selling on eBay.SHG
*Anthony - I suggest that you call these folks if you can't turn up local salvage.Jeff
*Anthony, If your in or near western NY, check out Houseparts on 540 South Ave. Rochester, NY 14620 at http://www.historichouseparts.com and you can call toll free: 888-558-2329, they can ship to you. Or if you prefer, check out Horsefeathers on 346 Connecticut St. Buffalo, NY 14213 at http://www.horsefeathers-antiques.com and you can call at 716-882-1581. I have seen these sash pulleys at both locations, good luck.
*Anthony, Too late... I just junked about 30 pairs of sash pulleys and weights last week. Have you tried calling a local company that deals with replacement windows? Jon
*Try blainewindow.com.
*I have a wooden box full of them in the garage (came with the house). If in SE Michigan drop me a line.
*Anthony, Then again if you are in/around Garland, Texas check out: Nostalgic Warehouse, phone 1-800-522-7336 and their website is at: http://www.nostalgicwarehouse.com I did a search there and came up with only other links to similar stores throughout the southwest and even one in Spokane. Good luck.
*AnthonyWhen you do get some in don't oil or grease them. That will only make a mess and attract dust and grit that will eventually jam them up. Use teflon dry lube instead. You can find the stuff at most any bicycle shops.
Can anyone refer me to a source for sash-weight pulleys? I've come back empty-handed from our local architectural salvage companies, and the only source I can find online is located in England.
