Satin Nickel Hinge Screws
Daft_Craftsman | Posted in General Discussion on October 21, 2007 11:16am
Where do I find satin nickel hinge screws to use with satin nickel hinges?
I’d like to replace the standard screws with 3″ screws to anchor the frame into the studs.  I’ve looked at McFeelys, but haven’t seen any.  It’s difficult to search the web for an item like this.
Any help is appreciated.  Thanks.
    BillHartmann | Oct 21, 2007 11:23pm | #1
    Lee Valley has a number of different screw finishes. Don't know the size or which finishes are available.
    1. Daft_Craftsman | Oct 21, 2007 11:29pm | #4
      Thanks, I'll give Lee Valley a try.
  2. Hackinatit | Oct 21, 2007 11:24pm | #2
    Stainless hides pretty well.
    "Fortunately, the ideas of individual liberty, private property, freedom of contract and association, personal responsibility and liability, and government power as the primary enemy of liberty and property, will not die out as long as there is a human race, simply because they are true and the truth supports itself."
    Hans-Hermann Hoppe
    1. Daft_Craftsman | Oct 21, 2007 11:30pm | #5
      Thanks.
  3. Snort | Oct 21, 2007 11:28pm | #3
    We've taken bright screws and "buffed" the heads with 220grit
    Someone's got it in for me, they're planting stories in the press
    Whoever it is I wish they'd cut it out but when they will I can only guess.
    They say I shot a man named Gray and took his wife to Italy,
    She inherited a million bucks and when she died it came to me.
    I can't help it if I'm lucky.
    shelternerd | Oct 21, 2007 11:30pm | #6
    I've been using galvanized 3" deck screws for that.
  5. Piffin | Oct 22, 2007 03:16am | #7
    http://www.jamestowndistributors.com/userportal/search_category.do?categoryName=Fasteners&categoryId=1&page=GRID
    If anybody has what you are looking for Jamestown does.
    For special stuff, a phone call is better thaan the catalouge though. Sometimes they have what they don't show.
    Me - I'd probably use stainless ands buff the sheen off
  6. davidmeiland | Oct 22, 2007 03:18am | #8
    Might be worth trying McMaster-Carr.
      Gene_Davis | Oct 22, 2007 03:37am | #9
      The satin nickel finish on plumbingware is essentially a plating, done on a brass substrate.  I believe it is the same for hinges.
      To my knowledge, no one does a satin nickel plating on screws.  But I could be wrong.
      The best place to go for an answer is to a full line commercial hardware jobber, the kind of supplier that sells, per specification and schedule, to commercial GCs.  They'll know for sure.
      1. Piffin | Oct 22, 2007 04:07am | #10
        It is unlikely that anyone would invest much trouble plating nickle over a brass screw. VBrass is the weakest kind of screw material I have ever used. It is there only when a low strength, corrosion-free material is neeeded. bronze is a much better screw cchoice for strength.BTW, while most stainless steel is a chromium alloy, some SS is made with nickle in the mix
        1. BillBrennen | Oct 22, 2007 06:27am | #11
          Piffin,All the common 300 series stainless steels contain both nickle and chromium. I'm with you on substituting stainless and buffing the heads if it really needs it. Scotch-Brite pads do a good job for me.Bill
  7. LeeLamb | Oct 22, 2007 02:21pm | #12
    Take stainless steel screws and "satin" the heads with a wire wheel mounted in your grinder. A second or two each and you're done.  Watch your fingers - wire wheels have no consciences.
    Good luck.
  8. User avater
    IMERC | Nov 18, 2007 06:38am | #13
    3mscrubbie run over a galvinized scew a few times..
    WOW!!! What a Ride!
    1. Daft_Craftsman | Nov 18, 2007 07:21pm | #14
      Great tip.
      Thank you.
      1. Lansdown | Nov 18, 2007 07:49pm | #15
        Here are 2 sources you might try:http://www.hardwaresource.comhttp://www.signaturehardware.com
        IMERC | Nov 19, 2007 04:26am | #16
        or do the same to a SS screw..
Drafting the 2027 IRC
  • The New Old Colonial
