I am working on an old church in Maine. I am repairing and replacing many of the old scarfed clapboards. I have tried many different techniques to scarf the boards and have found using a slick takes me about 8-10 minutes per board to manufacture them. Has anyone else come across this problem? and what was your efficient solution. Thanks Ed.
Is this novelty siding? Some places still carry it.
if you are talking about the end joints being scarfed.. this was done with a hatchet.. the claps were not very long.. and they were usually applied over vertical sheathing in the colonial houses..
the claps were about 3' long and scarfed on each end to about 30 deg. in the face plane and about 60 deg in the front to back plane...
they were installed with a shingling hatchet and the scarf was cut with the same tool
you can see a lot of this on the restoration work done by Newport Restoration when Doris Duke started restoring Newport..
you can set up a radial arm saw .. or a miter saw to cut this double bevel as a reasonable aproximation of duplicating the hatchet cut
look towards the boat building industry. Usually they use a power planer with a jig set to the 1:8 or so scarfing ratio. Ive seen a jig one can build on or around the boat building sites. THey were using a basic power planer not the more door oriented PC long planer.
It was a pretty simple jig. A ramp that mimiced the scarf ratio, the planer rode on the edges and viola the scarf was created.
Basically the wood was slid into the jig and a pass or two produced the scarfing joint.
You can also do this to mill in the coved shape. Vary blade depth, and angle of the runner clamped onto the tablesaw to get the shape you need. Make an eighth inch pass each time.
1. I have made simple coved crown moulding with the table saw setup Pif shows, and it works quite well...once you get the approach angle and blade height worked out. It does take some hand cleanup though.
2. Can someone post a picture of a scarfed clapboard? IHNFI what you're talking about.
Do it right, or do it twice.
