Schluter-Kerdi board to redo an in-place shower
Your plan should work as long as you add enough support behind the kerdi board (horizontaI nailers/battens/ shims etc) but I cant image why you couldnt cut the existing shower up into pieces and remove it leaving the walls intact.
I probably should just cut it out. I was trying to minimize mess and time as it's the only bathroom in the house. But you're right. I'm coming around to it. The corners are all curves and will require a lot of shimming to turn into right angles. Was hoping there's an existing product specifically to go over old acrylic shower enclosures.
You can even tile over tile, but your tile may only be adhered to a plaster wall and that isn't a good substrate. You could also use a product like Durock concrete board with an applied Kerdi waterproofing membrane. ...or the Kerdi board with integrated membrane as you suggest. (The Durock option is the cheaper option though.)
You'll be assuming that there is no mold/rot behind the shower walls.
Why not go with a Kerdi shower pan while you're at it.--but they do get expensive for a large shower bases.
I actually suspect the worst behind the existing walls. So yes, I should just cut it out in pieces and do it from scratch. it would be so cool though if there were thick rubber-backed, adjustable "studs grids" that you could just screw into an existing acrylic shower, make a nice rectangle and then wall over. Double the waterproofing ;-)
