Scratch Coat necessary? Thin brick & Thin-set over extruded lath
CplDevilDog | Posted in Construction Techniques on July 8, 2010 07:09am
Good morning,
Interior installation of 3/4″ Thin Brick veneer over plywood and extruded metal lath using Modified Thin-set.
Should I use a Scratch Coat or just back-butter, press firmly and give a little wiggle?
  1. CplDevilDog | Jul 08, 2010 07:20am | #1
    Expanded Metal Lath
    2 Hours of sleep Tthhhpppp!!
  2. DanH | Jul 08, 2010 07:55am | #2
    Never done that, but in the days before cement board used expanded metal under tile.  There I skimmed the wire with thinset first and let that set before spreading the coat for setting the tile.  Didn't scratch it, though.
  3. Piffin | Jul 08, 2010 06:12pm | #3
    Why metal lathe instead of cement bd?
  4. Clewless1 | Jul 10, 2010 10:24am | #4
    Not sure, but I think metal lath would dictate the scratch coat ... but I'm not a tiling expert.
    1. DanH | Jul 10, 2010 12:21pm | #5
      Doesn't the lath make it hard to scratch?
      1. Clewless1 | Jul 10, 2010 01:46pm | #6
        A 'scratch' coat I think is simply a rough base coat ... not troweled smooth. Maybe w/ like stucco they used to intentionally 'rough it up' a bit. You don't really "scratch" it per se' I don't think.
        1. DanH | Jul 10, 2010 03:21pm | #7
          The origin of the term "scratch coat" comes from the fact that, when plastering, the plasterer would actually scratch it with a sort of comb.
          1. Piffin | Jul 10, 2010 04:41pm | #8
            anything to give it tooth for the next coat.
            Plaster on lathe is
            Scratch
            Brown
            Finish veneer
            Lathje dictates a fill coat that could be called scratch, but he is making his work harder by using scratch and lather instead of just using cement bd
  5. raywill49 | Jul 30, 2010 10:06am | #9
    Thin Brick Substrate
    Whether interior or exterior, a substrate consisting of cement board, waterproof joints and thin set is typically quicker, less expensive and can provide a long term warranty. When consulting with architects and builders, we do not recommend metal lath/scratch coat systems for thin brick or stone.
Old House Air-Sealing Basics
