Screen Porch Posts
merlvern | Posted in General Discussion on September 22, 2006 11:10am
i’m replacing all the posts on my screened in porch and putting in new double doors.
one of the issues with the existing structure is that the 4×4 pt posts are twisted and cause the existing door/jamb to be out of plumb and stick, not to mention that it’s falling apart anyway.
my question is: is there a type of post (i was thinking of laminated something) that i can use that i can count on being straight TILL I DIE, or close to it? btw i may use the posts as the jamb, and the “sill” is brick.
thanks
  1. MSA1 | Sep 22, 2006 11:59pm | #1
    How bout wrapping the 4x4 in 1x material slightly larger than the post? That way it wont matter if it twists. Or maybe a round steel post also wrapped in 1x material.
  2. calvin | Sep 23, 2006 12:48am | #2
    4x4 cedar or fir.
    The cedar around here I pick from a fence installer.  Not all good but some are sweet.  About 12-15 bucks for a 8 footer.
    Fir, rough sawn / s4s are usually nice and straight-way more per ea.
    NW Ohio.
    Quittin' Time
    NickNukeEm | Sep 23, 2006 01:03am | #3
    Clear cedar 4x4.  Not cheap - maybe $35-40 each, but well worth the money.
    "I am the master of my fate, I am the captain of my soul."  Invictus, by Henley.
    McDesign | Sep 23, 2006 02:31am | #4
    Not sure of your vertical structural needs, but I have made hollow 4x4 posts with (4) pieces of true 1" thick CYP, with a lock miter at the corners.  Cut the lock miters (kind of a bevel with a bump) with a router, smear glue, slide 'em together, pin it with some nails, and they don't seen to twist.
    HD sells 1" thick SYP stair treads; you can rip and straighten two lengths from a piece of that.
    Edited 9/22/2006 7:41 pm by McDesign
    1. merlvern | Sep 25, 2006 05:12pm | #6
      thanks for replying.,
      what's cyp or syp?i was thinking of laminating some of the new "fake" wood products but wasn't sure of the strength
        McDesign | Sep 25, 2006 08:18pm | #8
        cyp is clear yellow pine - just a grade of syp with no knots; syp is southern yellow pine - easy to get in my area and nice to work with.
        1. merlvern | Sep 25, 2006 08:36pm | #9
          ok....duhthanks for the help
  5. wrudiger | Sep 23, 2006 03:37am | #5
    This stuff doesn't twist either:
    Clear heart KD redwood (thanks Zak!).  How much equity do you have in that house - you're going to need it if you go this route!
    1. merlvern | Sep 25, 2006 05:13pm | #7
      i'm going to cover the posts with 1x material and paint that's really beautiful though.
  6. DoRight | Sep 26, 2006 02:56am | #10
    Till you die?   . . . . HOw old are you?   LOL!
    1. merlvern | Sep 26, 2006 02:49pm | #11
      as if you don't know what i mean! lol
