My DW deck gun seems to have grown a pair of legs and walked out of my trailer. Otherwise known as, I can’t find it and need a new one.
I only bought dewalt because when the last one broke the store had a DW instock and I had a job to finish.
Question is now that I have a little time to buy, what do you like for a high-torque screwgun? Stick with Dewalt? Bosch, Makita, Mill., Hilti?
I use it mostly for decking, backer board, and a little sheetrock and subflooring.
Looked back through the search and did not find a decent and recent thread
-Day
I still have and use my original drywall screwgun.
Milwaukee.
http://www.quittintime.com/
Me too
I can't recommend a specific brand because my 30 year old B&D screwgun refuses to die, even though sometimes I wish it would... but I do know that if I were to get another screwgun, I would sacrifice some of the speed that my current gun has ( 0 - 4,000 rpm) for a little more torque. It seems like 0 - 2,500 rpm should still be more than enough speed for drywall and the added torque would make it more useful for other applications.
I'm surprised that you would use a true high-speed drywall screw gun for decking. I would think it would spin the screw too fast. But whatever works. Have you considered a cordless impact driver? it would be perfect for the tasks you list.
It was probably one of the dual purpose guns, 2500 rpm. I think an impact would be better on decks though. I have a corded Makita impact that will work all day. I'm not big on cordless because I don't use them often enough.
Edited 7/30/2009 8:47 am ET by Dam_inspector
Milwaukee...
WOW!!! What a Ride!
I have the newest Milwaukee 28v drill. Not impressed with it at all. batteries are already having trouble keeping a charge. the drill is a year or so old now.
I refuse to accept that there are limitations to what we can accomplish. Pete Draganic
Take life as a test and shoot for a better score each day. Matt Garcia
high torque deck guns are corded...
WOW!!! What a Ride!
good point... doesn't change the fact that I am not impressed with Milwaukee's cordless screw gun.
doesn't change the fact that the DW company is something to be thought well of either...
apples and oranges....
WOW!!! What a Ride!
For deck work this would be my choice:
http://makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=455
Scott.
I have the original version 6950. It's great, I think a little less power than than that one, but plenty for decks.
http://www.milwaukeetool.com/ProductCategory.aspx?CategoryName=SC%3a++Adjustable+Clutch+Screwdrivers
WOW!!! What a Ride!
I have an old Porter cable that has a lot of torque.
You can take the steel nose cone off (for drywall), and put a torque nose on it.
It is heavy and the steel nose cone for drywall takes away some of the magnetism for holding screws.
When I bought it (30 years ago) I was framing/drywalling with 16 Ga. studs and the guns with plastic noses cones were breaking.
Still runs great but i don't use it much anymore.
Will Rogers
I've got that same gun, it doesn't look in the same condition. I've lost the nose and pretty beat up. But is got alot to it as far as performance . I remember it being sold as a decking gun. As far durability awesome.
Another vote for an Impact driver.
Life will never be the same again.
Makita or Milwaukee.
Got a makita 14.4 LION set with an impact in it that I use the heck out of but there are times I want corded unit with depth set for larger stuff like screwing down 1000 sqft of decking. I had a Dewalt DW257
http://www.dewalt.com/us/products/tool_detail.asp?productID=54Looks like Milwaukee it is this time.
Found this
http://www.cpomilwaukee.com/screwdrivers/general_purpose_screwdrivers/6791-81.htmlThanks
-Day
consider the 6580....
WOW!!! What a Ride!
IMERC,
What am I missing on the 6580? Isn't it just a corded version of a normal cordless drill/driver? I've got several cordless drills. What I use the deck gun for is I set the depth, lock the trigger on, and start putting screws in. I like that I can't overdrive if I hit a soft spot or underdrive if I hit a knot which is a problem with a clutch. My mind kind of moves onto the next screw spot while the current one is going in so I do tend to overdrive. I don't see the 6580 working here? Am I missing something?
-Day
Yer right, go with the other gun if you want a positive depth stop.
RPM's... the 6580 has one more step down in the gear case hence thwe lower speed and higher torque......
also the 6580 will run #5 TEKs...
did I mention more versatility???
BTW... had the 6791... gave it away...
WOW!!! What a Ride!
Edited 7/30/2009 7:14 pm by IMERC
http://search.cpomilwaukee.com/search?keywords=6580-20&submit=GO
WOW!!! What a Ride!
QuickDrive kit with the Makita motor. Available with several different DeWalt motors too, I think.
j
Doesn't anyone use the Senco Duraspins?
I used them while working for a few mos. with a deck crew and really liked them. Sure beat bending over to screw decking.
I always wanted to get a couple, just thought it odd that nobody in this discussion has mentioned them.
Is there something I should know?
DC
Self-fed guns are great work wise, my problem lies with fastener availability and selection. I can't always get the type of fastener I want when I want it. If I run out of screws on a project I can't stop by the True Value (small hardware store) and buy another box. I have to go find the a fastener supply or lowes (selection is slim, no SS or hardi screws for the duraspins) or order them online. Just how I view it
-Day
