screws
pamilyn | Posted in General Discussion on April 12, 2005 11:26am
I hope that got your attention! I need to take out a few boards on my deck that are rotten. They were put in with Philips head screws. The homeowner in all his/her  wisdom then painted the deck (Yes painted) and filled in all the screw heads. I can’t get them out. Any ideas out there?  Pamilyn
  1. DonCanDo | Apr 12, 2005 11:41pm | #1
    I might try buying a few "disposable" screwdrivers and hammer them into the screw head.  It might be difficult to tell exactly where the screw is, but hopefully the self-centering feature of Phillips bits will work to your advantage.  Slotted screws would be even more difficult.
    If that doesn't work, I would probably resort to cutting the deck boards just to one side of the screw and prying the boards off.  That should leave the reluctant screw projecting by itself.  At that point, a vise grip should work.  If they happen to be hardened (not likely), you can just break them off flush.
    -Don
  2. PhillGiles | Apr 13, 2005 12:08am | #2
    There are always dozens of ways to 'skin a cat', and circumstances can greatly affect which you choose. In this case, you've strongly implied that all the boards you will be removing are trashed and will be replaced. Therefore, it's easy to jump to the conclusion that all the screws are in those expendible boards. Right ?
    If we're still on the same page, then this is just like removing rotten boards where the screw-heads have been plugged. One method is to use a small hole-saw (bi-metal, a little bigger ID than the screw-head; take the pilot drill out; drill down around the screws and pull the boards off leaving the screws c/w their little columns of wood; use visegrips to back the screws out.
    Phill Giles
    The Unionville Woodwright
    Unionville, Ontario
  3. PenobscotMan | Apr 13, 2005 12:09am | #3
    If there aren't too many screws, or if you have infinite patience,, you can clean the slots in the screw heads with a utility knife.  That will allow the screwdriver to grip.
    1. pamilyn | Apr 13, 2005 12:38am | #5
      Not many screws but not much patience either :) I think I will just have to cut the board up. Why didn't I think of that? Thanks all. Pamilyn
      1. FNbenthayer | Apr 13, 2005 02:31am | #6
        You can also take an old or cheap screwdriver and heat the tip til it glows and place it in position on the screw, don't turn it, the paint will bubble out.
        I do a bunch at a time, then go back and unscrew them.
        The awful thing is that beauty is mysterious as well as terrible. God and the devil are fighting there, and the battlefield is the heart of man.- Fyodor Dostoyevski
        1. pamilyn | Apr 13, 2005 08:53am | #12
          Great Idea!!! I have a heat gun. Pamilyn
    2. UncleDunc | Apr 13, 2005 05:35am | #7
      >> ... clean the slots in the screw heads with a utility knife.
      I'd try a scratch awl first.
        Sphere | Apr 13, 2005 06:00pm | #23
        off subject here..
        I need a TAP...5/16 x 36 TPI..you have a link to MSC?
        It might be q 7.62 by ( one) pitch MM...
        I remain flummoxed
        " Do not add to the world's confusion, by speaking in unclear terms"
        1. UncleDunc | Apr 13, 2005 07:02pm | #27
          http://www.mscdirect.comAccording to Machinery's Handbook, 5/16 x 36 TPI is a UNS thread. Unified National Special, which I read as "standard, but not very standard."7.62 x 1 mm isn't even close, 0.015" too small diameter and 25.4 TPI.What are you trying to fix?
            Sphere | Apr 13, 2005 07:42pm | #29
            Thank ya...I found it,
             A shell casing for a .308 needs a OAL of X
            (target rounds, sierra and Norma brass)
            X= OAL and chamber to lands, a 700 bull barell and chamberd @! .308 needs a "finder" in this case a  Dummy round, to determine the OAL of said load.
            James has kit for that, but the dummy is not able to be chambered, as it is,
            We need to resize for Norma brass or retap a primer pocket for the gauge that he bought.
            Sierra 170;s  are not spec. to .001 tolerances..so the laoding can be off by a bunch.
            I just reloaded my .45/70 shells,,,where is the Buffolo?
          2. JohnT8 | Apr 13, 2005 09:06pm | #34
            On one of my outdoor channels was a gun show testing big handguns.  Desert Eagles and kin.  I think the top rated one was a S&W.  Maybe a 500?  When your 6-shooter only holds 5 rounds, you know the bullets are getting big.
            http://firearms.smith-wesson.com/store/index.php3?cat=293531&item=1207228&sw_activeTab=1
            For those times when you feel you need a hand cannon.  :)
            Personally I like having my wrist attached to my arm, so I'll stick with smaller ones.jt8
            Things turn out best for the people who make the best of the way things turn out.  -- John R. Wooden
          IMERC | Apr 13, 2005 08:03pm | #31
          try wholesale tool.. megga cheaper..
          http://www.wstool.com
          WOW!!!   What a Ride!
          Forget the primal scream,  just ROAR!!!
            Sphere | Apr 13, 2005 08:15pm | #32
            Dude, thanks.I just got 2 sent to him from MSC
            I shot 3 bug holes @ 200 yds...I needa  shoulder pad.
            .308 with 75g nnntf powder, sierra noslers,,,,170 g HP
            BUG HOLES!!!!  my MOA was .05 in a 7 shot group
  4. JohnT8 | Apr 13, 2005 12:24am | #4
    Can you get up underneath it and get a Sawzall blade between the board and joist?
    I suppose a metal detector might tell you where to dig for the nails from the top, but that might be hit and miss.
    Depending on what the ho filled the screw holes with, you might be able to belt sand and find the filled (won't work if its a filler designed to match the wood) spots, but that wouldn't be much fun.  Top solution would probably be my first choice.
    And if that isn't an option, how about Sawzall'ing the bad planks up.  that should tell you in a hurry where the buried screws are located.
  5. jrnbj | Apr 13, 2005 05:38am | #8
    Impact driver....not the electric kind but the kind you hit with a hammer....Sears'd have um....
    1. pamilyn | Apr 13, 2005 09:01am | #13
      I don't know what an impact driver is and if I did I would not buy one for for 20 frigging screws. I HATE this. I only need to replace 2 boards on this deck. It is my one and only rental property that I bought last year. I thought I was handy! You folks may be hearing from me alot.!! Pamilyn. I am going to saw zaw the boards and try to get the screws out. Does this sound feasible? Pamilyn
        IMERC | Apr 13, 2005 09:06am | #14
        sure it does..
        or split the boards from around the screws and grab the friggin' screws with a pair of vise grips...
        WOW!!!   What a Ride!
        1. andybuildz | Apr 13, 2005 02:49pm | #16
          jack hammerThe secret of Zen in two words is, "Not always so"!
            fishdog | Apr 15, 2005 09:17am | #47
            I agree with imerc.try the jack hammer.then just bend over the old screws into the top of the dry rotted joist.they'll flush out.send photos and an update on joist conditions.
          fishdog | Apr 15, 2005 09:09am | #46
          "Right on" just pull the damn mushy rotten boards out of there.next
      2. Mac_Built | Apr 13, 2005 09:21am | #15
        OPTION 1 -
        Can you get to the under side of the deck? Using a sawzall to cut the decking screws away from the joists from underneath would be less hazardous to the neighboring decking. OPTION 2 -
        Use a sawzall to cut away a chunk of the deck board between two joists.
        Turn the sawzall on its side and cut the screws connecting the board to one of the joists. Pry up the deck board and use sawzall to cut the next set of screws on the next joist. Continue to pry up the decking board as you cut screws to allow you access to the next joist in line.OPTION 3 -
        Most home improvement stores sell sets of screw extractors that attach to your drill and bite into the head of stubborn screws to get a grip. That might be an option for you. You'll want to put your weight behind the screwgun when applying pressure on the screws.Good luck!MacView Image
        BossHog | Apr 13, 2005 03:47pm | #17
        "I don't know what an impact driver is and if I did I would not buy one for for 20 frigging screws."
        Most of us would look at tis as an EXCUSE to buy a new tool.
        Ya just gotta understand the mentality here. (-:
        Every great movement must experience three stages: ridicule, discussion, adoption [John Stuart Mill]
        1. PenobscotMan | Apr 13, 2005 04:46pm | #19
          There may be a gender issue here.  I'm guessing pamilyn is a woman.  We (men) are shameless in using any pretext to convince our wives that we need to buy a new tool.  Pamilyn is probably more realistic.
            BossHog | Apr 13, 2005 05:07pm | #20
            I hadn't looked at the name, and thought about gender. I guess this will be another women for everyone to drool over and ask for pictures.......
            You can always spot a well informed man - his views are the same as yours [Ilka Chase]
          2. JohnT8 | Apr 13, 2005 05:21pm | #21
            Women with power tools excite most of these guys.    Although... saw a woman (chick) driving a big-#### dually a couple days ago.  Thought, "man, that's cool!"
            :)jt8
            BossHog | Apr 13, 2005 05:43pm | #22
            "Women with power tools excite most of these guys. ".
            That's kinda what I was getting at.
            I'm surprised that any women hang around here, the way some of them have been treated in the past.
            One mosquito to another: "Sure, I believe in reincarnation -- in my previous life I was an IRS agent!" [Bob Thaves] (Frank & Ernest)
            JeffBuck | Apr 14, 2005 03:20am | #37
            ahh ... don't be so hard on yerself.
            Jeff  Buck Construction
               Artistry in Carpentry
                    Pgh, PA
          5. PenobscotMan | Apr 13, 2005 06:35pm | #24
            Oh, Oink oink
        2. pamilyn | Apr 13, 2005 06:42pm | #25
          Hey, I am usually in cooks talk. You should hear the talk about buying kitchen equipment. Shameless!! Pamilyn
            DDay | Apr 13, 2005 06:53pm | #26
            A pretty simple, painless solution could be to put some paint remover on the screw head to at least soften but probably disolve the paint then use a drill and back the screws out.  If you cannot get the bit to grap the screw head, try using an extractor bit.  They are designed to take out damaged screws, and are available for fairly cheap money at sears, lowes, hd and good local lumber yards and tool houses.
          2. JohnT8 | Apr 13, 2005 07:21pm | #28
            I was in a showroom a couple weeks back.  Saw a neat looking fridge.  Almost passed out when I saw the $10k price tag.  GAWD!    And those commercial-looking stoves can be just as bad.
            I can buy a lot of tools for $10k!jt8
          3. Piffin | Apr 14, 2005 12:28am | #36
            Why, all you need is a whoppin big knife and a frying pan!
          4. pamilyn | Apr 14, 2005 07:41pm | #40
            A 10 inch chefs knife and my cast iron skillet ought to do it. See, who needs sears...Pamilyn...Thanks everyone, lots of great ideas. I think I will go with the hole saw idea. Sounds the simplest...
          5. pm22 | Apr 15, 2005 02:56am | #41
            The first and easiest thing to try is the scratch awl idea. A dental pick? Get the paint out and your done.
            If you have to resort to the hole saw idea [+ is stripped], the smallest hole saw will be 9/16". The pilot bit will get in the way. Take it out. The hole saw will go all over the place. So first, before you remove the pilot] drill a hole in a scrap of plywood. Then center that hole over the balky screw and secure it. This will hold your hole saw in position while it gets started.
            I don't know what all the gun talk is all about, but why not just use a .50 caliber machine gun. [If you have one.] Works real well.
            ~Peter
          6. DanH | Apr 15, 2005 03:35am | #42
            Just get a bigger hole saw (about 1") and set the pilot just off-center so it doesn't hit the screw.Of course, few hole saws will really do 1.5" depth, so you still have to chisel out the area, remove the screw, and then remove the board. Might as well just use the chisel.
          7. dude | Apr 14, 2005 02:45pm | #39
            drill off head using drill slightly bigger than head , pound up or pry up board after which you either  drive screws sideways with hammer to break off ,or cut off with sawsall and metal blade or turn out with vise grips.
          IMERC | Apr 13, 2005 08:00pm | #30
          just one screw should be enough reason..
          WOW!!!   What a Ride!
        4. Piffin | Apr 14, 2005 12:26am | #35
          It's a guy thing
      4. DanH | Apr 13, 2005 04:44pm | #18
        An impact driver is cheap -- maybe 20-30 bucks -- and a good thing to have, but if you're willing to sacrifice the boards, just chisel out around the screws (use an old/cheap chisel, since you'll likely hit a screw a few times) and then grab them with Vice Grips.If that doesn't work, then split the boards through the screw holes with the chisel.
      5. Pierre1 | Apr 15, 2005 07:41am | #45
        "I am going to saw zaw the boards and try to get the screws out. Does this sound feasible?"
        Pamilyn - Don't waste your time with chef knives, hole saws, vice grips or saw zaws.<!----><!---->
        You could easily punch those nasty screws out with 75g nnntf in a .05 MOA 700 bulled .308.  Don’t bother with the paint, the 170g HP Noslers will take care of it for you.<!---->
    fishdog | Apr 13, 2005 05:45am | #9
    DONT OVER THINK IT.YOUR SWAPING THE OLD BOARDS OUT .DO WHAT U GOT TO DO ON THE FIRST BOARD .THEN THE OTHERS WILL COME OUT EASY.
  7. DanH | Apr 13, 2005 05:46am | #10
    First dab paint remover on the screws to soften the paint. After an appropriate wait for the remover to work, use the impact driver described above to cut through the paint and loosen the screws.
  8. User avater
    hammer1 | Apr 13, 2005 05:46am | #11
    I second the awl. Tap it a couple times and the filler will pop out. Tap it a few more times in the slots to clean out. To remove the screws with a drill you have to lean on it hard to keep the bit from stripping the head.
  9. csnow | Apr 13, 2005 09:05pm | #33
    What you could do is take an angle grinder and dig the edge in until the screw head is ground off.  Then remove boards, and twist the remains of the screws out with vise grips.
    Or, for the impatient, just take a big chisel and big hammer, and shred the boards into shards. Better yet, if you can get below, you can pound upwards with a big hammer to pop them away.
  10. byrnesie | Apr 14, 2005 05:50am | #38
    holesaw around the screws, lift the board off then crack off the peice with a chisel.
  11. User avater
    jagwah | Apr 15, 2005 05:37am | #43
    View Image Screw extractor Found at Woodcraft or Rockler
    1. Sancho | Apr 15, 2005 07:26am | #44
      I dont know how good you are with power tools. If you know your way around around a skill saw......
      Since it is only a couple of boards....
      I would locate the screws. Take a skill saw and score the the boards length wise about 3/4 debth of the boards inna couple of places for about 12 " or so.  Becareful not to hit the screws. If you hit the screws it wont be pretty....blades dont like screws......Then try to split the boards with a chisel or wedge and the boards should just split and take some vise grips and unscrew the screws....Buck Construction  View Image
              Pgh, PA
Putting Drywall Sanders to the Test: Power, Precision, and Dust Control
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
