sds plus wood chisels?
ANDYSZ2 | Posted in Tools for Home Building on November 4, 2006 11:48am
Has anyone used the wood chisels for sds plus hammer drills.
Bosch makes them in 4-5 sizes but I was looking for a set.
ANDYSZ2
WHY DO I HAVE TO EXPLAIN TO FRIENDS AND FAMILY THAT BEING A SOLE PROPRIETOR IS A REAL JOB?
REMODELER/PUNCHOUT SPECIALIST
  1. nikkiwood | Nov 04, 2006 11:57pm | #1
    Yup --- in the right application, they work great.
    "It is what we learn after we think we know it all, that counts."
    John Wooden 1910-
      basswood | Nov 05, 2006 12:00am | #2
      Wow, so how do you use them? (I thought Andy was joking).
        IMERC | Nov 05, 2006 12:24am | #4
        lock the HD in hammer mode and and have at it..
      2. nikkiwood | Nov 06, 2006 08:06am | #11
        <<so how do you use them?>>Having a wood chisel for your SDS is a little like owning a Multimaster -- once you have it, you'll find all kinds of uses for the thing. I certainly wouldn't use it for anything that required a fine touch -- it is mainly for hogging off wood where no other tool is applicable. The last time I used it, we were setting new windows in an old house, and some were too tight a fit because the framing wasn't plumb. The wood chisel worked slick to slice off the 1/4" or so that I needed to slip the window in place.I certainly wouldn't buy an SDS drill to make use of the wood chisel; but in my case I already had the drill, so I just picked up the wood chisel (which I think was less than $20), and occasionally, I find it handy.********************************************************
        John Wooden 1910-
    IMERC | Nov 05, 2006 12:22am | #3
    slick...
    WOW!!! What a Ride!
    McDesign | Nov 05, 2006 12:25am | #5
    Yes - I have a set from Highland Hardware - they're Czech, I think.  Work well.
    1. ANDYSZ2 | Nov 05, 2006 12:43am | #6
      Now I know your secret for extreme pace on portico.
      Do you have a brand name and does highland hardware have a web site or catalog?
    2. ANDYSZ2 | Nov 05, 2006 12:55am | #7
      Found them!!!!
      Thanks Forrest
      1. ANDYSZ2 | Nov 05, 2006 01:07am | #8
        Forrest I was thinking these would work great on doing replacement window sills where you can't get a saw cut to the outer ends of the sill and other places where it is hard to swing hammer while holding chisel.
        Do you use them frequently?
          McDesign | Nov 05, 2006 01:25am | #9
          I usewd them more before I got a Multimaster!  Someday I'm gonna' carve a tree stumb into a face . . .
          1. ANDYSZ2 | Nov 05, 2006 03:07am | #10
            Man thats gotta hurt!
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
