SDS vs SDS-Plus
krjone01 | Posted in Tools for Home Building on November 11, 2005 08:21am
I am thinking of purchasing a SDS type rotary hammer and I am confused by the difference between SDS and SDS-Plus. I realize that SDS-Max is a whole different animal, but  I have been searching the discussions and found references that say SDS & SDS-Plus are the same thing. However, other internet sources say that SDS and SDS-Plus use different size shanks. Can someone give me the real story here or point me to the specs ??
Edited 11/11/2005 12:22 pm ET by krjone01
  1. JulianTracy | Nov 11, 2005 09:29pm | #1
    I recently purchased a Milwaukee SDS-plus rotary hammer, and I think you are correct that they are one in the same. If they are not, then all of the brands newer entries in the smaller rotary hammer market are in indeed sds-plus.
    One thing that I found when looking into the purchase was that if you buy one of the
    1 1/8" capacity units - you can get a true 3-mode rotary hammer - it'll do light chipping work (hammer only), hammer drill mode, and plain drill mode (rotation only).
    Even though I was somewhat inclined to buy a larger (better, right?) unit, I realized that anything larger and it would operate in a hammer only mode. Any larger and then you end up having to buy a dedicated chipping hammer.
    After ripping up a original tile floor install by hand, I was certain that the next time I'd do it with a chisel bit on a hammer drill.
    Like the Milwaukee, but only bought it because there was a screaming deal on it at Amazon last year. Most folks give bosch the props in regards to rotary hammers.
    Some of the 7/8" and 1" capacity models take sds bits, but again, offer no chipping feature.
    JT
  2. JohnSprung | Nov 11, 2005 10:54pm | #2
    Plain and Plus are the same, Max is bigger.
    -- J.S.
    1. nikkiwood | Nov 14, 2005 06:37am | #3
      Yes, but the SDS will not take the SDS Plus bits (and vice versa), right?********************************************************
      "It is what we learn after we think we know it all, that counts."
      John Wooden 1910-
      1. JohnSprung | Nov 14, 2005 11:35pm | #4
        I think they're probably interchangeable.  But I'm not absolutely sure that I've ever seen a non-Plus SDS bit.  It looks like the "Plus" is just a marketing ploy.
        -- J.S.
        1. BryanSayer | Nov 15, 2005 01:37am | #5
          Anyone every seen a decent set of SDS bits? I hate going out and buying one bit for the task at hand, but I haven't located any sets.
          1. JulianTracy | Nov 15, 2005 03:48am | #9
            I have the Bosch 7 pc set that retails for $30-50, but had recently found a bunch of Dewalt 7 pc sets 3/16" - 1/2" that sold for about $15 set. Look on Ebay - that's where I've bought most of my bits.JT
          2. rasconc | Nov 15, 2005 06:00am | #10
            I got one of the cheap sets on ebay, they look fine but have not used them.  I have bought a bunch of Rawls and Bosch bits on ebay and very satisfied.
            http://cgi.ebay.com/17-SDS-HAMMER-DRILL-BIT-CHISEL-KIT-CONCRETE-QUALITY_W0QQitemZ6011862363QQcategoryZ50383QQrdZ1QQcmdZViewItem
  3. rasconc | Nov 15, 2005 02:20am | #6
    TE-C
    SDS + bit connection end, for use with: TE 1, TE 5, TE 5A, TE 6A, TE 15, TE 15C, TE 18, TE 25
    • More products
    TE-Y
    SDS Max bit connection end, for use with: TE 55, TE 75, TE 76, TE76-ATC
    • More products
    TE-T
    SDS - bit connection end, for use with: TE 35
    • More products
    http://www.us.hilti.com/holus/modules/prcat/prca_navigation.jsp?OID=-12068
    If I read it right then an SDS bit would fit in a plus drill but not vice versa and forget the max in anything but max.
    Bob
    1. JohnSprung | Nov 15, 2005 02:40am | #7
      Right, the diameter of Max is much bigger, like about twice the size of plus.  I'll have to pull them all out tonight and look.
      -- J.S.
      1. rasconc | Nov 15, 2005 03:36am | #8
        I did not think they were larger diameter, just the double slot at 12 o'clock in pict.
        1. JonE | Nov 15, 2005 06:45pm | #11
          The SDS-Max is a larger diameter bit - somewhere around half an inch or more.  The SDS+ (or plain SDS) is about 1/4" or 5/16" diameter shank, and a different pattern.   My Bosch hammer is an SDS-Max, but I use the smaller SDS+ bits with an adapter.   I have never seen an adapter to use an SDS-Max bit in a smaller SDS+ tool, and I doubt there is or will be such a thing.
          1. BillBrennen | Nov 15, 2005 08:37pm | #12
            SDS is 10mm shank, while SDS-MAX is 20mm shank. Four times the metal section.Bill
          2. rasconc | Nov 16, 2005 02:33am | #13
            Thanks, I was only going by the Hilti pictures I pasted.  Guess they were not to scale and just showed configuration.
