Seal Below Grade Hole – Concrete
| Posted in Construction Techniques on July 13, 2002 10:08am
I need to run a 1/2-inch piece of metallic electrical conduit through my concrete foundation below grade. I will be boring the hole with a roto-hammer and masonry bit. What is a good method of sealing the hole to make it water-proof. Thanks, Ed.
  1. MarkCadioli | Jul 14, 2002 02:53am | #1
    Blow out the hole with compressed air. Place your conduit and seal with one of the polyurethane sealants. Sikaflex would be my personal choice.
    http://www.quittintime.com
    1. EdMayer | Jul 14, 2002 05:25am | #2
      Thank you for the reply, Ed.
      1. junkhound | Jul 14, 2002 05:48am | #3
        or smply mix a stiff cement paste grout and trowel it in.
        1. MarkCadioli | Jul 14, 2002 08:38am | #4
          Cement paste has a high shrinkage rate..you will be allowing the possibilities of water access.regards
          Mark
          1. 4Lorn1 | Jul 14, 2002 11:01am | #5
            In an industrial setting they sometimes use a rubber boot, similar to an automotive CV boot, that is bolted to the wall with a flange and to the pipe with a sleeve. The pipe is run through an oversized hole to prevent binding and has a flexible joint inside the wall to prevent breakage. These units are not cheap but provide a reliable seal even under water and allow 10, or so degrees of lateral movement and several inches in the axial direction. These are available for pipe sizes from 1/2" to well over 2'. An extreme solution that assures a seal even with lots of ground movement as with floating foundations and clay fills.
            CloudHidden | Jul 15, 2002 02:48am | #7
            Would hydraulic cement make a difference?
          3. junkhound | Jul 15, 2002 03:38am | #8
            re:shrinkage:Stiff mix a must if using cement to seal.
            Minuteman silos & LCCs (80 ft water head) used only grout to seal - granted, the seal also included a non-pourous weld to the 1/2" steel liner.
          4. EdMayer | Jul 15, 2002 03:50am | #9
            Thanks for all your replies, I appreciate it, Ed.
    2. Wolvie | Jul 15, 2002 12:41am | #6
      you have Sikaflex in Aussie land? Wow - yer moving up in the world! ;-)Woe to the cook whose sauce has no sting- Chaucer
