Sealing a roof vent
| Posted in General Discussion on August 11, 2003 04:33am
Hi everyone my name is cookie, Hows every one doing?
I would like to know in the September issue 2003 #157 I have a question on the article  [ adding a bathroom fan ] having never attempted a roof vent the article seemed very clear about the project, except for sealing the roof vent and flashing.should all flashing and vent be sealed with a roof tar ? And would it be a good idea to cover flashing that’s sealed with ice and water shield? Any advice would be helpful…….
            Thank you Cookie
  1. Piffin | Aug 11, 2003 07:53pm | #1
    as a general rule, keeping the laps facing downhill will keep it from leaking but the side flange on vent caps is pretty narow sometimes. That makes it better to run a bead of caulk there.
    1. cookieb | Aug 12, 2003 02:28am | #4
      Thank you Piffin for responding.
  2. MojoMan | Aug 12, 2003 12:02am | #2
    If you use a little ice & water barrier UNDER the shingles and vent flange downhill from top of the opening and a nice covering OVER the flange and under the shingles uphill from the bottom of the opening, very little tar should be needed. Perhaps a little along the edges as Piffin suggested and a bit under the lower edge of the flange for wind-blown water and a dab on the few nail heads that may be holding the lower edge of the flange down tight. Ice & water barrier sticks very nicely to the metal flange. You probably only need to go about a foot in all directions.
    Echoing what Piffin said, water usually flows downhill. I amazed at how often I see roof shingles OVER the lower part of vent stack flashings. I wonder where these folks think that water will go.
    Al Mollitor, Sharon MA
    1. cookieb | Aug 12, 2003 02:26am | #3
      Thank you Al for responding.
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
