Sealing a wood to concrete joint
greenstar | Posted in Construction Techniques on July 7, 2007 10:11am
Does anyone know if there a system out there to gasket a wood to concrete vertical joint between a concrete foundation wall and wood wall. Its not something I want to do but…
  1. Piffin | Jul 07, 2007 11:08pm | #1
    Say more about conditions please. Need for 'gasket' and sealing implies moisture, but wood moving from moisture breaks seals....
    Below grade?
    I can't picture the need for this in a verticle joint....
  2. chickenfarmer | Jul 09, 2007 12:15am | #2
    There's an outfit that advertises in FHB called Resource Conservation Technology or something like that.
    In addition to carrying EPDM and related roofing stuff, I seem to recall seeing lots of profiles of gaskets for the sill and to seal windows and stuff like that.  I'd look further but I've gotta run.
  3. Piffin | Jul 09, 2007 12:42am | #3
    Hello - anybody there?
    1. jackplane | Jul 09, 2007 01:23am | #4
      greenstar6 has left for Nebulon,Sector 27. He'll be back shortly...Expert since 10 am.
    2. greenstar | Jul 09, 2007 02:54am | #5
      I'm here
      1. Piffin | Jul 09, 2007 03:53am | #6
        Come in, Greenstar6...OK, can you say more to descrinbe what this joint is and what you are sealing? That can help us help you
          IMERC | Jul 09, 2007 04:32am | #8
          yur operating on channel 22, ULF band and Greenstar6 is on channel 86 in the UHF wave length...
          just tell him to bed the wood with Vulcum... the message will catch up to him someday..
          Edited 7/8/2007 9:34 pm by IMERC
          1. greenstar | Jul 10, 2007 02:06am | #9
            Okay folks, I'm attaching the drawings that illustrate the situation. On page 1 south wall-the new bumpout foundation walls SHOULD tie into an existing fieldstone foundation. However the homeowner wants the new concrete wall to be only foot long (concrete is shaded black)and tie into a new 2x6 stud wall creating a vertical seam between wood wall and concrete. The east wall will be a complete stud wall while the north wall will be all concrete tying into the fieldstone foundation but then creating another vertical joint between concrete and wood wall on the outside corner. The reasons why the homeowner wants this are too numerous to get into. I would simply pour a complete concrete basement wall tying into the fieldstone foundations on both sides. So the issue is making the two vertical joints leakproof. Thanks everybody.
            IMERC | Jul 10, 2007 02:15am | #10
            somebody else's turn to try to get the OP to post those pics in a manageble / veiwing size...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
    loucarabasi | Jul 09, 2007 04:07am | #7
    Green, I'm doing the same thing now. I plan on making a verticle saw cut in my block wall and run a L channel flashing. after that i will use ice and water membrane over top the flashing. I will side over it after. I will caulk the saw cut and flashing with a good caulk.
    Hope this helps, Lou
