Sealing air loss from fireplace
Tark | Posted in Energy, Heating & Insulation on December 6, 2009 07:28am
We have a fireplace in our house that has a good working damper as well as one of those little trap doors on the floor to dump all the ashes. Although they close properly, I can still feel a draft and want to minimize the amount of heated air lost when we’re not using it.
Does anyone have any good ideas of how to temporary seal a fireplace?
Thanks,
Tark
  1. DanH | Dec 06, 2009 08:02am | #1
    Get a tight-fitting fireplace door or cover. In the olden days there were covers that fit over the fireplaces in the summer, but nothing says you couldn't use one in the winter, when the fireplace is not in use.
    This country will not be a permanently good place for any of us to live in unless we make it a reasonably good place for all of us to live in.  --Theodore Roosevelt
  2. MHolladay | Dec 06, 2009 01:41pm | #2
    Tark,
    There are two possible product you might consider:
    The Fireplace DraftStopper from Battic Door:  http://www.batticdoor.com/DraftStopper.htm
    The Chimney Balloon:  http://www.chimneyballoon.us/chimneyballoon.html
    Martin Holladay, senior editor
    GreenBuildingAdvisor.com
    1. Tark | Dec 06, 2009 11:00pm | #4
      Thanks Martin,That is just what I'm looking for Thanks!Tark
  3. Clewless1 | Dec 06, 2009 03:21pm | #3
    How about the weatherstripping like around your oven door. I want to say an asbestos weatherstrip, but it's probably not made of that any more. This assumes you have a lip that the lid/damper shuts against, too.
    Martin's idea works for longer periods of time of no use, I think.
  4. shufflefoot | Dec 07, 2009 02:19am | #5
    I am a chimney sweep and lurk around these parts due to my love of quality homes and construction. What I recommend to my customers is a Lymance top mounting damper. It is a cast aluminum assembly that sits on top of the flue. A stainless cable is then lowered and mounted to a small handle to the inside of the firebox wall. These dampers are said to be 80% more efficient than a steel plate throat damper. They also will serve to keep you flue "preheated" ensuring a good draft when ready to burn. Let me know if you have any questions, I could send you a brochure if you need it. A set of glass doors is also another route, but they can never be installed to be as tight as a top mount damper and can be quite expensive.
