Sealing Below Grade Foundation Hole…
bk73 | Posted in General Discussion on May 16, 2011 09:19am
I ran a pipe through the foundation wall and need to seal around it.  What is the best method, I read Sikaflex but not sure what exact type.  Its only about 1′ below grade, and I dug a hole under it and put gravel below it so I don’t think I will be a problem but just want to be sure.
Thanks.
Brad
  1. calvin | May 16, 2011 09:56am | #1
    I've had good luck
    using backer rod stuffed in the hole around the pipe-maybe a 1/2" in from the face of the foundation.  Then I've used whatever brand of Urethane caulk I had handy-usually a Tremco product, but Sika makes good quality too.
    Same thing on the inside-though I might try to get a bit nicer finish by running tape around the hole and the pipe-caulk and tool, peel the tape off for a nice crisp edge.  Use backerrod here also.
  • A Postwar Comeback
