Sealing concrete slab with drylok or some liquid applied membrane?
user-7764336 | Posted in Construction Techniques on October 29, 2021 01:53pm
I have a home on a concrete slab and the previous owners put down a tile floor with some adhesive directly onto the concrete.  I can pull the tiles up incredibly easy and I’m assuming the adhesive never probably set due to the moisture of the slab.  Can I paint some sort of drylok product or membrane over the slab to seal and prevent moisture from ruining any floor I put over the slab?  I want to either tile or put vinyl plank with a vapor barrier.  The entire home is a slab so I just wonder if I “seal” the top with some sort of liquid barrier – is that bad for the slab, where does that moisture go?  Thanks in advance!
  1. greg_e | Oct 29, 2021 03:03pm | #1
    When you say the previous owner put down a "tile" floor with "adhesive" do you mean they put down a lvt tile floor with glue or a ceramic tile floor with mortar?
    Is there efflorescence or other signs of moisture accumulation under the tile?
    Is the glue/mortar separating from the tile or from the concrete? What does the coverage look like?
    Have you done a moisture test on the concrete?
    1. user-7764336 | Oct 30, 2021 01:24pm | #2
      I have not done a moisture test. By a moisture test do you mean use a hygrometer or tape some poly to the concrete to see if moisture builds up? There wasn't mortar used from what I can tell - the coverage of what I'm guessing adhesive doesn't look awful, I can see trowel lines, but as soon as I knocked one tile loose, I could almost smell the moisture and the adhesive still looks like it hasn't cured - its almost still malleable - this floor was probably installed 15 years ago. I've attached some pictures of the 1 tile I peeled back. On the right hand side is where I removed a different floor that was covered with a cabinet and I'm about to start removing this tile floor.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
