sealing joint btwn basement floor/walls
jjc155 | Posted in General Discussion on December 29, 2006 03:22am
I’m getting ready to finsh my basement in my house. After cleaning ou the basement and having a minor leak/crack fixed I checked the joint between the floor and the walls. After 3.5 year the house has settled and in a couple of places the caulk in the joint is either cracked or otherwise compromised. There has be no issues with water from the joint anywhere in the basement, but I want to re-seal the joint before I throw up my walls around the perimeter of the basement.
What kind of caulk should I use for this. I have some Sika Contractors Choice Self leveling sealant that I have used in concrete drive/sidewalk joints/cracks in the past and it has held up good, but this joint is deeper than these other cracks. Would this sealant work or is there something else that I should use? Any other advice would be appreciated as well.
Thanks in advance,
J-
  1. calvin | Dec 29, 2006 04:00am | #1
    Foam backer rod to shorten the depth and a good Urethane caulk, easily found at a masonry/concrete supply.  If there is still movement the urethane will take quite a bit of it v. zero.  This will help seal against radon and insect vermin.  Water with enough force can still push this stuff out.
    http://www.quittintime.com/
    1. jjc155 | Dec 29, 2006 05:29am | #2
      Thanks for the info, sounds like the Sika will work and I'll get some backer rod and have at it.
      Thanks again,
      J-
      1. calvin | Dec 29, 2006 05:44am | #3
        The self leveling crack filler will find a way...........out.  I'd recommend the caulk.A great place for Information, Comraderie, and a sucker punch.
        1. jjc155 | Dec 29, 2006 08:46am | #4
          Calvin, that is what I was thinking too. Is there any caulk that u would recommend? This is all going to end up under the sill of the wall so something that will last a LONG time is prefered.
          J-
          1. calvin | Dec 29, 2006 02:01pm | #5
            sikaflex I believe it is called.  Same urethane type caulk as the selfleveling, only not free flowing (the self leveling part.)
            I use Dymonic or Vulkem 116  both by Tremco
            These hi grade Urethane sealants are available at any good masonry or concrete supply.A great place for Information, Comraderie, and a sucker punch.
          2. jjc155 | Dec 29, 2006 06:13pm | #6
            Thanks Calvin,
            J-
          3. calvin | Dec 29, 2006 08:50pm | #7
            no problem.  See you're from ypsi, give me a call if you need area info, I'm just outside Toledo.
            And welcome to BTA great place for Information, Comraderie, and a sucker punch.
          4. jjc155 | Dec 29, 2006 08:53pm | #8
            Thanks again/Happy New Year
            J-
Fast, Accurate Wall Framing
