Securing Copper sheets
ChrisV | Posted in Construction Techniques on July 17, 2005 06:13am
Hi All,
 I need to bid on a job which includes securing 4′ x 6′ copper sheets (16oz = ~.025) to built out wall mounts (same size as the copper sheet). There will be fasteners on the outer edges only, so I need to use an adhesive everywhere else. Any ideas on an adhesive that will have the holding stength but will not be too thick to show on the front side?
Thanks,
Chris
  1. seeyou | Jul 17, 2005 02:30pm | #1
    Is this exterior or in a conditioned space? You'll have some serious oil-canning if it's outside with that big of a sheet.
    I'm not green anymore.
    1. ChrisV | Jul 18, 2005 01:22am | #3
      Cu,
      It's an interior application.
      Chris
      1. seeyou | Jul 18, 2005 01:44am | #4
        I think I'd let it float in the middle if it's secured around the perimeter. That's a mighty big sheet of copper to handle without half-mooning it. Good luck.I'm not green anymore.
  2. WayneL5 | Jul 17, 2005 03:08pm | #2
    I think David Marks on his show Woodworks has fastened copper sheet to a substrate for a garden gate.  Check out http://www.diynetwork.com to search for the episode.
