Self cleaning shower enclosures
| Posted in General Discussion on October 4, 2001 03:17am
A few months back, I read about a new shower enclosure having a proprietary coating that reduced surface tension and was purported to stay clean.
I can’t recall the magazine that had the article although it sounds like something from Popular Sciences’s “What’s New ” section. Has anyone heard
of a coating for glass enclosures that helps keep the unit cleaner than what we can expect from normal use? I’m aware of the new squirt-on stuff that
reduces surface tension and has a bit of detergent as well for an “after sower fix” . The article implied that the surface was treated and was permanent.
  1. Raymond_Liccini | Oct 04, 2001 03:17pm | #1
    I can't recall the magazine that had the article although it sounds like something from Popular Sciences's "What's New " section. Has anyone heard
    of a coating for glass enclosures that helps keep the unit cleaner than what we can expect from normal use? I'm aware of the new squirt-on stuff that
    reduces surface tension and has a bit of detergent as well for an "after sower fix" . The article implied that the surface was treated and was permanent.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
