I’m looking at Senco finish nailers and was wondering if it is worth the money/hassel of going with the 40 just so I can fire 2.5″ nails vs. the 2″ max the lighter, less expensive gun fires. Thoughts?
Newer pressure treatments don't offer the same rot and decay resistance. Follow these simple strategies to give outdoor lumber its best chance of survival.
I need the 2-1/2" for door jambs (because you might have 1/2" of shims) and thick molding over 5/8" drywall. I've got the 40 and no trouble in 7 or 8 yrs.
*If you are only buying one gun, get the 40. Then you can use it on old plaster homes as well as those door jambs. If you had 2 guns, the 30 would get used 75% of the time.
*Ditto the SFN40. When you find you're in need of 2 1/2" you're gonna kick yourself- unless you want an excuse to buy another toy.
*The 40 is a great gun! The 21/2" helps with crown on plaster walls.
*Both are excellent. But since the 40 does everything the 30 does and more, well you get the idea.
*Go with the 40. I looked long and hard at it, 'cause I love my senco framer. In the end I got a PC 250. It's not a senco, but it is all the tool I will ever need.
