Senco Nailer leaks
alecs | Posted in Tools for Home Building on October 4, 2003 03:17am
I have a Senco FN25 XP, the 18 gage brad nailer.  I’ve used it less than half a dozen times for DIY stuff.  I was putting up some trim, when I pulled the trigger, I happened to run out of nails at the same time that the compressor restarted (100′ of hose away).  Shouldn’t have really mattered that the compressor restarted, since the regulator was set for 80# and the compressor restarts around 90.
Anyway, after that incident, the gun began to leak significantly at the little firing piston that the trigger actuates.  I took out the trigger assembly and removed and reinstalled the firing piston.  Now it doesn’t seem to leak anymore, but I haven’t tried using it again.  Anyone know what caused this, and what, if anything, I need to do?
I’m kind of disappointed that this happened, after all the good reviews that Senco gets on this site.  I’ve literally only shot about 200 nails with the thing.
Thanks for any tips.
    IMERC | Oct 04, 2003 06:49am | #1
    Crud. Chipped O ring. Lack of lube. All three
      alecs | Oct 04, 2003 04:52pm | #2
      The O-rings looked good, and this nailer is supposedly oil-free.  So that leaves crud as the possible culprit.  Will check for crud.  thanks.
        IMERC | Oct 04, 2003 06:51pm | #3
        Air tools that sit w/o use for a period of time have been known to act "funny" when they are put back into service.
        Kinda like a marathon ESPN weekend and the getting out of the chair or off the couch...
Big Doors Have Big Challenges
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
