What is the difference between the SFN40 and the SFN1. Besides the fact that the SFN40 can shoot a 2 1/2″ nail, I can’t tell the difference.
Thank you
I have the sfn-1 and maybe it's been replaced by the sfn 30. Here's the infor and you can find more at http://www.senco.com/con_rem/index.asp
SFN40
TOOL SPECIFICATIONS
Height: 11-1/4" (286 mm)
Length: 13" (330 mm)
Weight: 4.7 lbs. (2.1 kg)
Lip Length: 5/16" (8 mm)
Fastener Capacity: 104
Reg. Operating Pressure:
80-110 p.s.i.g. (5.5-7.6 BAR)
Collation: Paper Tape
Mode of Operation: Available with either Restrictive Trigger or Dual Action activating mechanisms
15-Gauge. Brad Head Finishing Nails. 1-1/4"-2-1/2" 4d to 8d. Smooth. Capacity 100.
FEATURES AND BENEFITS PROJECTS MORE INFORMATION
Neverlube Design means no tool lubrication to stain fine woods
Adjustable depth-of-drive allows for flush drive or precision countersinking at lower air pressure
Low recoil - more tool power reduces effort needed for each drive
Includes hard plastic case
SFN30
TOOL SPECIFICATIONS
Height: 9-5/8" (245 mm)
Length: 12" (305 mm)
Weight: 3.6 lbs. (1.6 kg)
Lip Length: 3/8" (9 mm)
70-120 p.s.i.g. (4.76-8.16 BAR)
15 Gauge. Brad-Head Finishing Nails. 1"-2" 2d to 6d. Smooth. Capacity 104.
Lightweight - 3.6 lbs makes it easy to maneuver in tight spots
Handy belthooks adjust for left or right hand users to keep the tool close by
Includes case
*Will:The sfn1 is an old design. The sfn30 and sfn40 are newer. They are very light, powerful and all around good finish nailers. I highly recommend them.
What is the difference between the SFN40 and the SFN1. Besides the fact that the SFN40 can shoot a 2 1/2" nail, I can't tell the difference.
Thank you
