separating direct vent fluepipe
weekendwarriorben | Posted in General Discussion on July 3, 2009 05:24am
I have a Duravent Direct Vent flue for a gas stove in a woodframed “chimney”. I need to replace the chase cover, so the top section of the flue needs to be separated from the rest so I can slide the chasecover off and on. I tried twisting and pulling, but the sections don’t seem to want to separate. Is there a trick to this?
Ben
  1. DanH | Jul 03, 2009 06:01am | #1
    I assume you know they lock together with a bayonet lock.
    As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
    1. weekendwarriorben | Jul 03, 2009 06:41am | #2
      Dan, that's what I thought too. From the looks of it there are 4 indentations where the pipes connect, but from the way those indents look I don't see how they could be bajonet locks. I'll try again in the morning.
      Ben
    fengelman | Jul 03, 2009 09:26am | #3
    twist them till the seams line up...they will always seperate in that configuration....
    I wish I didn't know now, what I didn't know then
    1. Piffin | Jul 03, 2009 12:43pm | #5
      The way I hear this, he is having a hard time twisting the parts in the first place.but if this was not put together with concern for seam alignment, that suggestion would not help. It only needs to untwist about 1-1/2" to free up the lock joint, but to do what you say copuld have him trying to untwist as much as 330°
      1. Bing187 | Jul 03, 2009 03:51pm | #6
        I hope he doesn't do that. Would be pretty funny to be in the house when the wood stove starts turning around..;)
  3. Piffin | Jul 03, 2009 12:40pm | #4
    after it has been together and used a while, some creosote on the inside can act like a glue and you have to be more forceful.
    tapping with a hammer all the way around the joint a couple times can help break that seal a bit.
    But I am not sure you need to separate the pipe itself. Just taking the cap off should get you where you want to go.
    Also, check to see if there are pop rivets or sheet metal screws in the joints to stabilize.
    only other thing I can think of is some idjit used some silly cones in the joint
