septic pipe freeze-up
duanescott | Posted in General Discussion on November 4, 2009 07:17am
I seek advice on how to insulate a partially exposed pvc (septic) drainage pipe that comes out of my new addition and goes to my septic tank.  Several factors prevented any other options other than a partially exposed pipe.  I am concerned that the pipe may freeze up and clog this winter due to the exposed portion.  I can only cover it with 3 or 4 inches of fill dirt due to foundation height.  Is there an insulation product for use in the ground?  Approximately 4+ feet is exposed, with half of the pvc above ground, the other half setting in the ground as it then gradually sinks down under the ground and into the holding tank about 10 feet away.  Any suggestions would be greatly appreciated.
  1. Scott | Nov 04, 2009 09:32pm | #1
    You could box it in with 2" SM foam, then backfill as best you can. Keep in mind that septic systems generate a bit of heat as they "cook", and that there will be a bit of flow.
    Three to four inches isn't a lot of cover, though. How cold does it get in your area?
    1. rdesigns | Nov 04, 2009 09:44pm | #2
      What he said, plus, after you've done your best effort of insulating, be vigilant with regard to the inside plumbing--don't allow a drip to develop in any faucet or fixture because a small amount of drainage would be subject to freezing, whereas a slug of water from any fixture in the addition will actually add heat to the pipe.
      cabanillas3 | Nov 05, 2009 03:18am | #3
      How about something like hay or pine straw? it could be reused in the spring. The OP didn't put any location info in his profile, but we used to use straw to protect plants in Virginia when I was a little kid.jose c.
      "Though I don't think" added Deep Thought "that you're going to like it."
      1. Scott | Nov 05, 2009 03:38am | #5
        >>>How about something like hay or pine straw?Like you say, that would work in Virginia. I'm afraid it wouldn't do here, unless you laid it a couple of fee deep.
    3. duanescott | Nov 05, 2009 03:50am | #6
      Scott,
      Thanks for the suggestion of boxing the area in.  I live in northern Michigan, so we get  a lot of insulating snow cover quickly and  can easily have single digit temperatures for 30 days or more (like we did last winter).  It can get nasty cold up here and I guess that is why I am concerned.
      duanescott
  2. DanH | Nov 05, 2009 03:34am | #4
    Just a general point that you only want to insulate the TOP (and sides, to some extent) of the pipe. You want heat to come in from the earth below.
    (BTW, where do you live, and how cold does it get there?)
    A strong nation, like a strong person, can afford to be gentle, firm, thoughtful, and restrained. It can afford to extend a helping hand to others. It's a weak nation, like a weak person, that must behave with bluster and boasting and rashness and other signs of insecurity. --Jimmy Carter
    1. duanescott | Nov 05, 2009 04:00am | #7
      DanH,
      Thanks for the "insulate on top" suggestion.  I live in northwest Michigan and the temperatures can be nasty... single digits for 30 days or more as we had last season.  Fortunately we also have heavy, lake effect, snowfall, which insulates the ground rather effectively... if I don't foolishly shovel it off, which I have in the past.
      duanescott
      1. DanH | Nov 05, 2009 04:17am | #8
        Yeah, basically, if you have the room, you'd want to insulate maybe 4 feet horizontally from the pipe in each direction. This creates a warm spot in the ground.
      2. Junkman001 | Nov 05, 2009 05:38am | #12
        If its that close to the surface, a chase has merit,  need to be concerned about mechanical damage.
        MikeInsert initially amusing but ultimately annoying catch phrase here.
        1. GregGibson | Nov 05, 2009 03:01pm | #13
          Any possibility of a raised bed planter, kitchen herb garden or flower box variety ? 6x6's three or four high, you could line the bottom with plenty of foam, topsoil might only be 12" deep. Might be attractive.Greg
          1. gusfhb | Nov 05, 2009 03:36pm | #14
            I lived with an exposed septic pipe in my house for 13 years. It never froze. Eastern Mass weather in single digits negative occasionally.
          2. DickRussell | Nov 05, 2009 04:14pm | #15
            I have a pipe that is exposed like that also, in NH, although only for about 18" with air contact, then very shallow covering for another foot or so. No real problems with it.Building on the insulate-above-cover-lightly suggestions (which will work, much like the "Frost Protected Shallow Foundation [FPSF] technique), how about this for a little added protection to put below the 2" of foam above the pipe:Dig a narrow trench about three feet deep under the four feet of pipe. Place a thick (1/4" ?) plate of aluminum in the trench, with the top edge right up to the pipe. Place 1" XPS foam on either side of the plate, leaving perhaps the bottom foot and top few inches of plate not covered. Backfill the trench, add the 2" XPS foam on top and whatever dirt or other protection you can layer over the foam.The idea would be to use the highly conducting plate to help draw heat up from the ground, without losing much along the way to the soil.Would I do this if it were my place? Frankly no. It's belts-suspenders protection on top of already more-than-adequate insurance (the layer of foam on top of the pipe), all to address a problem unlikely to occur if the pipe is sloped properly. Every time a faucet is run or a toilet is flushed, a slug of heat enters the pipe anyway.
    Dinosaur | Nov 05, 2009 04:28am | #9
    Ideally you would build some sort of a pipe chase over this pipe that could be well insulated. Often this is done with rigid XPS foam board cut and taped together with red Glasclad (Tuck) sheathing tape. Raw like that it does look a little 'trailer park' tho; so you might want to build a more finished looking chase out of some scrap siding or whatever's handy that looks decent.
    However, the most important thing is that this waste line must be sloped enough so that it will drain completely every time. It must not have any dips in it that could hold a 'belly' of water which will freeze.
    Last bit of advice would be to make sure you've got a clean-out that will allow you to stick a steamer in there if it does freeze. You don't want to be digging this up in the middle of the winter.
    Dinosaur
    foolish men call Justice....
      Sphere | Nov 05, 2009 05:03am | #10
      " a steamer.."
      Snork.Spheramid Enterprises Architectural Woodworks
        Dinosaur | Nov 05, 2009 06:22pm | #17
        " a steamer.."
        Snork.
        What's funny?
        Dinosaur
        1. Scott | Nov 05, 2009 08:38pm | #18
          At your own risk:http://www.urbandictionary.com/define.php?term=steamer
            Dinosaur | Nov 05, 2009 10:12pm | #20
            When gutter slang so dominates the language that everything and anything one says is interpreted as either defecation or fornication, ya hafta wonder about the future of the race....
            Dinosaur
          2. frammer52 | Nov 05, 2009 10:21pm | #21
            >G<
          3. Scott | Nov 05, 2009 10:44pm | #22
            >>>ya hafta wonder about the future of the race.......and the English language... <grin>
            Dinosaur | Nov 05, 2009 10:56pm | #23
            Been wondering about that for 40 years already....
            Dinosaur
            cabanillas3 | Nov 06, 2009 12:39am | #24
            Go read Chaucer. Nothing new here, folks, move along please.jose c.
            Dinosaur | Nov 06, 2009 01:32am | #25
            Yah. I oughta check the 'definition' of 'Forty-Two' in that 'urban dictionary' but was afraid it would say something about the length of a 'steamer'.
            Chaucer was bawdy, but elegant and creative and funny. Shakespeare and Sheridan, too. And Molière as well, if you want to get a little non-English perspective to help you place things.
            This stuff, OTOH, is so utterly predictable that it is of no conceivable interest to anyone except those with the IQ of a retarded lump of igneous rock.
            Dinosaur
    2. duanescott | Nov 06, 2009 05:10am | #26
      Dinosaur,
      Great suggestions...thanks.  great name too.
      duanescott
  4. Junkman001 | Nov 05, 2009 05:35am | #11
    Might help if we knew if you were in Key west or Duluth.
    Mike
    1. duanescott | Nov 06, 2009 05:21am | #28
      /Junkman001,
      Closer to Duluth.  Northern Michigan...single digit temperatures and plenty of snow.
      duanescott
    hammer1 | Nov 05, 2009 05:45pm | #16
    Water doesn't stand in the pipe, it just flows through. There won't be any water in it to freeze. If there is, you have other problems.
    1. frammer52 | Nov 05, 2009 09:29pm | #19
      There won't be any water in it to freeze. If there is, you have other problems>>>>>>>>>>>>>>>>>>>>>>>>
      I agree completely.  I never worry if the pipe is burried just a little, there is plenty of warmth for the pipe to never freeze.  I have seen pictires of pipes in Alaska that are above ground all the time and they don't freeze often there.
    2. duanescott | Nov 06, 2009 05:15am | #27
      Hammer1,
      Good point, maybe I am overthinking this septic flow thing.
      duanescott
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
