Septic system- which is better
jimcco | Posted in General Discussion on November 20, 2009 09:41am
Will be building where there is only 6ft below floor elevation to bed rock. will be on a septic system so getting a 10ft to bottom type tank will be very difficult. If I set the tank on top of the bedrock it will take an ejector pump to get into a normal tank.
Is it a real PTA to use an ejector on the sewage line. I have delt with ejectors on the septic effluent with no trouble but not the inlet.
No aerobic tanks!!!!!!!!!!
  1. Scott | Nov 20, 2009 11:22pm | #1
    Blasting?
  2. davidmeiland | Nov 20, 2009 11:25pm | #2
    I would only base a whole-house sewer on an ejector pump if there were absolutely no other way. I'd rather hammer out the rock and make a hole for the tank. Can you get to the drain field by gravity if you do that? If you have to go with the pump then I'd also install a generator, unless you think your electric service is absolutely reliable.
    1. jimcco | Nov 21, 2009 12:24am | #4
      Not going to try to blast into this rock. Setting on top of rock will permit gravity to field. Already committed to stand-by generator.
      1. frede | Nov 21, 2009 03:26am | #5
        I had a similar situation when I built my house.  My septic system designer specified a "low boy" septic tank.  It's still a thousand gallon tank only its about 4.5 feet deep.  No problems after 7 years.  This may help you shoot for a gravity system, or at least minimize your ledge removal.
        1. plumbbill | Nov 21, 2009 04:16am | #7
          Gravity never fails.
          Moving parts will eventualy fail.
          Like Frede said there are "lowboy" tanks.
          Here's one from the plastic guys.
          Low Profile Septic Tanks
          Part Number:
          Snyder1050SepticLow2
          Capacity:
          1050 Gallons (PrePlumbed)
          Size:
          126"L x 60"W x 51"H
          USD Price:
          1399.99
          USD Shipping:
          CALL FOR PRICING
          Contact Us .
    popawheelie | Nov 20, 2009 11:53pm | #3
    Maybe I'm wrong but isn't Bed rock is a pretty large catagory.
    Could a backhoe dig it out?
    Is there layers to it?
    With the right contractor/equiptment it might come right out.
    "There are three kinds of men: The one that learns by reading, the few who learn by observation and the rest of them have to pee on the electric fence for themselves."
    Will Rogers
    Dinosaur | Nov 21, 2009 03:38am | #6
    Aside from the problem David pointed out (no drains if you lose electrical power), I don't see any problem with using a trash pump to hoist the crud up into the septic tank. If you've already committed to a standby genny, you oughta be good.
    We do this all the time with below-grade bathrooms and laundry rooms, so there's no reason it shouldn't work for draining the entire house although the size of the holding tank might have to be increased. A lot of them are plastic, about the size of a big garbage can, but I'm sure you can get bigger ones if necessary. Set the holding tank/pumping station below the floor of the basement with a grinder/trash pump in it, and away you go.
    Oh, yeah, put a high-level alarm in that holding tank to warn you if the pump craaps out, the float-switch jams, or the circuit-breaker kicks out for some reason.
    Dinosaur
    foolish men call Justice....
