In order to have my septic tank cleaned I need to locate the access cover. There is a piece of PVC pipe sticking up out of the ground about 20 feet away from the house that has a screw cap on it. There is a second PVC pipe coming out of the ground that has an ordinary cap on it and is somewhat lower in elevation. This pipe is also about 20 feet from the house and about 25 feet from the first pipe. The septic tank is not indicated on my property map. Anyone expert enough to be able to determine the probable location of the access cover? Thanks in advance.
![](https://images.finehomebuilding.com/app/uploads/2024/07/10133441/01232535-cali-valley-heads-east-feature-Large-thumb-16x9.jpeg)
Construct the intersecting gable on the main roof for a faster, easier-to-build assembly.
