I recently had two fiberglass tubs installed and the floor of the tub seems to give a little more than I had expected. I have access to an end of each of the tubs (which are open) through closet walls and would like to get something under the tub to firm it up. What would y’all recommend doing? Thanks, Kyle Ross.
The FHB Podcast crew offers expert advice on choosing the right insulation for the roof of a small, balloon-framed home.
I recently had two fiberglass tubs installed and the floor of the tub seems to give a little more than I had expected. I have access to an end of each of the tubs (which are open) through closet walls and would like to get something under the tub to firm it up. What would y'all recommend doing? Thanks, Kyle Ross.
Hi Kyle
I would fill the tub with water, reach underneath with a can of minimal-expanding foam and spray away. Try to spray just the center first, let it expand and dry for a while, then fill in around it. You don't want to distort the tub. Leave the water in overnight.
Good luck
jim
