Sewer backup into A/C condensate drain
HealeyBN7 | Posted in Energy, Heating & Insulation on December 5, 2005 07:34am
Great get this… I have guests over and the forced air gas heater stops working.  I check the circuit breaker and it is indeed tripped.  Reset – trip – repeat.
The handler, which is on a slab in a “basement/closet” is sitting in water.   I climb to the roof and attic – no leak.  Under the house  – dry.  As best I can tell about a gallon of water flowed back into the A/C condensate drain and flowed over the electricals. Nice.
It will be easy enough to clear the blockage, but one has to question the wisdom of hard plumbing the A/C drain to the sewer.  What were they thinking?  There is a 3/4″ PVC trap so no sewer gases escape which is good, but given the right conditions/blockage, the A/C drain becomes the lowest fixture.
I plan to disconnect the drain today and plumb the A/C to the outside even if it is a long run.  Any words of wisdom.
Edited 12/5/2005 1:32 pm ET by HealeyBN7
  1. jg | Dec 05, 2005 08:53pm | #1
    can you run the condensate line into a sump pit?
    1. HealeyBN7 | Dec 05, 2005 09:17pm | #2
      There are currently no provisions for a sump, as this is not supposed to be a wet area.
      1. jg | Dec 06, 2005 12:19am | #3
        sorry about that....pump to the outside seems the only option
    CapnMac | Dec 06, 2005 01:04am | #4
    That's a hard call to make.  My town practically mandates "wet venting" the condensate drain into the nearest stack (and the pan drain out the nearest gable and/or soffit) for a/c installations.
    Go to the "sister" town, and that's not permitted at all.  Except in commercial, where bothe drains can (if the inspector ok's it, a big if) just drain into a mop sink . . .
  3. SHG | Dec 06, 2005 01:08am | #5
    Healey BN7?
    Maybe Lucas made the unit?
    SHG
    '64 Healey BJ8
    For every complex problem, there is a solution that is clear, simple, and wrong.
    -H.L. Mencken
    1. HealeyBN7 | Dec 06, 2005 05:44am | #6
      Now if Lucas made the unit - All the smoke would have escaped, before that one fuse let go.
      Good to know there are other Healey fans here online.  Here is the only shot I have on this PC.
      Regarding my problem, looks like I will need to pump the condensate up a couple of feet to make it outside.
      1. HealeyBN7 | Dec 06, 2005 05:53am | #7
        Healey Pic for SHG
        1. SHG | Dec 06, 2005 01:46pm | #8
          Nice. but you need a bigger pic.  My son wants me to put a number on the car, but I don't know where the get them.  Here's mine.
        2. SHG | Dec 06, 2005 07:34pm | #9
          That's my 11 year old son practicing, so that when it's his car (the day after I die), he'll be able to look cool and meet chicks!
          1. HealeyBN7 | Dec 08, 2005 07:33pm | #10
            Very nice - my eight year old is always ready to take a spin regardless of the weather.
            I had my numbers made at a local sign shop.  I selected the font after looking at vintage photos, and they cut the vinyl from standard sign stock.  I was thinking about having them reproduce some of the old sponsor decals, but that is a later project.
            FWIW  - I tried the magnetic circles, but they slid right off the doors when provoked by the slightest bump.  My son old got quite a laugh that first time we tried them. "Dad, I think your numbers are back there at the last stop sign...." Oh well.
            The Healey Digest is a great resource and if you are not a member (it's free) you can sign up here http://www.team.net/cgi-bin/majorcool.  Rich Chrysler and Gary Andersen are experts and frequent contributiors.  Rarely does a question go unanswered and has international contributors (for example, when I rebuild my engine, I ended up sending my distributor to a Healey expert in Australia for recurving).
            Here is a shot without the numbers ...
          2. SHG | Dec 08, 2005 08:48pm | #11
            the car looks great, but I'm really jealous of the garage.
            Signed up for the digest too.
            I'm not sure I want a permanent number.  But I've now decided to pass on the magnetic ones.  Just one more thing to cross off my list.
            Scott
Old House Air-Sealing Basics
