Can anybody direct me to something that talks about repairing a roof with hand split cedar shakes?
Thank you…….
Here-I used "shake roof repair" in the search box above.
Web
(10)
Metal roofing? | Breaktime
If a repair becomes necessary the new patch will definitely distract from the ... My house was built in the 1740's with a shake roof - a ...
forums.finehomebuilding.com
forums.finehomebuilding.com/breaktime/general-discussion/metal-roofing-6
clipped from Google - 4/2011
Walking on cedar shake roofs | Breaktime
I have cedar shake on battens on my roof (not sure if I have the lingo ... like that and it's expensive for doing a one-time quick repair. ...
forums.finehomebuilding.com/breaktime/general-discussion/walking-cedar-shake-roofs
Cedar Shake Install | Breaktime
I've never installed cedar shake roofing before. Any advice/tips would be ... Mike Smith Rhode Island : Design / Build / Repair / Restore ...
forums.finehomebuilding.com/breaktime/construction-techniques/cedar-shake-install
Flat roof repair/replacement | Breaktime
As with any roof, keep people from drilling holes through it. ..... Material Choices. Inspire shake tiles ...
forums.finehomebuilding.com/breaktime/construction-techniques/flat-roof-repairreplacement
Cedar shake roof question | Breaktime
I haven't used it but I haven't done a wood roof in many years either. .... Mike Smith Rhode Island : Design / Build / Repair / Restore ...
forums.finehomebuilding.com/breaktime/general-discussion/cedar-shake-roof-question
Copper Gutters/Slate Roofing repair and replacement/expert roofing ...
One roofing company will give me an estimate Sept 28 and may get to the work mid -October. in the .... Material Choices. Inspire shake tiles ...
forums.finehomebuilding.com/breaktime/general-discussion/copper-guttersslate-roofing-repair-and-replacementexpert-roofing-advice
Rubber roof repair in winter | Breaktime
As far as I know, you can repair a rubber roof in cold weather. Certainly at 32 degrees. .... Material Choices. Inspire shake tiles ...
forums.finehomebuilding.com/breaktime/construction-techniques/rubber-roof-repair-winter
EPDM ROOF REPAIR | Breaktime
My 15 year old EPDM roof has become unglued about 8" from the drip edge on the .... I did an EPDM roof on an apartment building of mine. ...
forums.finehomebuilding.com/breaktime/general-discussion/epdm-roof-repair
Flat roof replacement....I know nothing. | Breaktime
I knew my flat roof was bad but just found out toady that it needs replacement ASAP. ..... Material Choices. Inspire shake tiles ...
forums.finehomebuilding.com/breaktime/general-discussion/flat-roof-replacementi-know-nothing
rot repair | Breaktime
(The house has a 15-year old cedar shake roof, but there. haven't been any other signs of moisture damage inside). ...
forums.finehomebuilding.com/breaktime/construction-techniques/rot-repair
1
2
3
4
5
6
7
8
9
10
