shark bite fittings and Pex
yojimbo2 | Posted in Construction Techniques on December 8, 2008 06:28am
I believe that this is my third thread on these two amazing products.
I recently saw a cordless copper pipe cutter by Milwaukee. Very sweet and fast. Then I realized that this thing is already obsolete, right out of the gate. The only time I work with copper pipe is when I am cutting it out to replace it with Pex.
On my current project, the house main does not completely shut off the water. I have never worked on a house where the main actually does completely shut off the water. In the past, the thought of soldering with a drip sent chills down my spine, as I knew I would be in for a long frustrating afternoon.
With Sharkbite fittings, I cut and then it is “plug and play”. Problem solved in seconds. They accept pex, copper and cpvc.
I just have to figure out what to do with all my copper pipe and fittings.
Sharkbite fittings cost on average about $5 a piece. This is cheap when compared to the time it takes to prepare and solder copper.
  1. Henley | Dec 09, 2008 01:47am | #1
    I've been using the Sharkbite fittings on my Home
    projects.Makes plumbing a breeze but I'm not bragging
    until I see them perform for a decade or so.
  2. pgproject | Dec 09, 2008 02:05am | #2
    Many places don't allow PEX (for example, San Francisco- no plastic pipe of any kind).
    1. mhole | Dec 09, 2008 02:48am | #3
      Interesting, I can't think of a place that I'd like to have semi rigid piping more than there.
      Still not sure about any overwhelming bennies of pex across the board. Got the tools. Use it when it makes sence.
      Certain situations - Sharkbites are the BEST.
    Dinosaur | Dec 09, 2008 03:39am | #4
    They cost $10 here. But even at $5, they're not cheap when compared to the time it takes to sweat a copper joint.
    It takes about 30 seconds to sweat a half-inch joint once the pipefitting is done (and you gotta do the pipefitting with Pex and Sharkbites, too). At my hourly rate, 30 secs comes out to about $0.33. Plus the cost of the fitting itself ($0.11 to $0.89), the MAPP gas, the Goldcrest, and the solder, I figure each joint costs the client a max of $1.75.
    Sure, I'll use a Sharkbite when it makes sense--tying in new copper to an existing PEX installation. But it's definitely a luxury item. I can't imagine doing a whole system with them.
    Dinosaur
    foolish men call Justice....
    1. mhole | Dec 09, 2008 03:53am | #5
      Waaay to expensive to do a whole house or system.
      In remodelling - temp cap off some lines, remove an outside spigot, tie in a new branch...
      Priceless.
      Coupla weeks ago, getting rid of an existing ext spigot. 1/2" copper feed. Put a 1/2" shark bite cap and a mini cutter in my pocket, shut off water, go into crawl. Deep breath, cut , cap.  Didn't even drain the line.
      Done - priceless.
    2. yojimbo2 | Dec 09, 2008 06:36am | #6
      Interesting breakdown. With Pex , joints are kept to a minimum in comparison to copper. On a run of copper you may have 10 joints, where you have to cut each piece of pipe as well as deal with the fittings. On similar run of pex you may encounter one, maybe two joints at most. Next you don't have a whole soldering set up to deal with, and then it is all plug and play, which only takes seconds.The only drawback so far is that the stores are still gearing up their selection of Shark Bite fittings.
        mmoogie | Dec 09, 2008 06:58am | #7
        >>The only drawback so far is that the stores are still gearing up their selection of Shark Bite fittings.<<That and it's hard to keep the run of pex looking good.Steve
  4. ponytl | Dec 09, 2008 07:07am | #8
    i would guess soon you will see most  pex manifolds made with shark bite type fittings...  same with the copper stub-outs...  it will be a no tool deal... cept a knife to cut it...
    most big box stores are going about 80% shark bite...  plumbers will be cry'n "now anyone can do my job"
    p
      popawheelie | Dec 09, 2008 08:44am | #9
      Good plumbers won't worry. There's plenty of ways for DIYs' to mess up. Even with pex and shark bites. Either they will mess it up or won't want to get dirty.
    intrepidcat | Dec 09, 2008 09:03am | #10
    I used a sharkbite recently on a repair job and it was easy and simple. Even for someone who hates to repair plumbing, like me.
    I'm really glad someone invented the sharkbite.
    deadmanmike | Dec 09, 2008 09:48am | #11
    Ditto.
    I just did a job where some tweaker(s) stole the copper water line right off the back of the building...under pressure....riiiiight.
    Anyway, of course the city water valve in the box doesn't completely shut off and I'm not looking forward to sweating copper in a trickling pipe 1' down in the mud.
    Sharkbite to the rescue!
  7. plumbbill | Dec 09, 2008 01:00pm | #12
    Sharkbite¯ concept is not that new.
    I have used a similar style fittings on drinking fountains, & instahots since the late 80's.
    Here's the kicker for those of you that think these things are the best thing since sliced bread & burry them in walls, floors, & ceilings.
    They use a rubber "O" ring to make the seal, ever see what water does to rubber?
    How many times have you replaced the flapper in your toilet cause it was warped & falling apart.
    The rubber "O" ring will eventually fail, & if the fitting is concealed how much will it cost to fix the damage in the name of cutting corners during the install?
    1. DanH | Dec 09, 2008 02:06pm | #13
      The cast iron water mains buried under the streets are sealed with rubber gaskets.
      The mark of the immature man is that he wants to die nobly for a cause, while the mark of a mature man is that he wants to live humbly for one. --Wilhelm Stekel
      1. plumbbill | Dec 09, 2008 02:14pm | #14
        Yup, & the eventualy fail too. CI is being phased out & replaced with ductile, but the same MJ's are on those & they fail over a period of time.
        Also 1.5" of rubber has a bit longer life than rubber that is 1/16" thick.
    2. BoJangles | Dec 09, 2008 04:04pm | #15
      ...and how about the rubber gasket in the crimp-on systems, such as the Ridgid?
      That whole concept makes me wonder how long these things are going to last.  I see so much of this on boiler piping jobs where the water is 180*.
      At least you can remove the Sharkbites if you have to, but the Ridgid is crimped on and can't be removed without cutting the whole area apart.
        mmoogie | Dec 09, 2008 05:25pm | #16
        What do you think about the pex fittings where you just expand the pex and a collar and you have thirty seconds to put the fitting in and then the memory of the pex shrinks it back around the fitting? No O-rings. Do you think the pex will fatigue eventually and loosen up?Steve
          FatRoman | Dec 09, 2008 05:39pm | #17
          I know he likes the Wirsbo/Uponor ones you are talking about, since he turned me on to them.And if they have a known failure rate, well, I don't want to hear about it now that they are in place :)'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
          1. plumbbill | Dec 09, 2008 07:49pm | #21
            Relax, Uponor has been around the longest. The failure came in the early 90's.
            & that failure was chemicals being introduced into the potable supply, not a pipe failure ;-)
        2. dbcabs | Dec 09, 2008 05:47pm | #18
          What I really like is that as a cabinetmaker who also installs what I build, I don't have to bring out the soldering torch! My insurance doesn't cover me if I burn down someones house doing plumbing. Sharkbites makes caps which are removable after sink base is in, and no more burnt finishes when plumber forgets to shield his torch (had to replace cabinet back once, real problem after everything's in place)
          davew
          1. plumbbill | Dec 09, 2008 07:57pm | #22
            As an expert in the art of soldering pipe I would go nuts if I had to solder every angle stop on under a sink.
            I have rarely seen a soldered angle stop, & never did I have a job that spec'd them to be used.
            We use on our lower bid jobs an angle stop that has the "O" ring & SS retention ring like Sharkbite. They are a one piece kinda ugly fitting, but I will admit they do work & have seen them hold up to 260 psi without failing----- was a bit scary though.
        3. plumbbill | Dec 09, 2008 07:47pm | #20
          Eventually yes, eventually everything fails.
          However polyethylene does out last rubber.
          I do prefer the Uponor expanding system over the other brands for a few reasons & one is that the pipe is expanded around the fitting which has less restriction than a fitting that has a smaller ID than the pipe.
        4. MikeHennessy | Dec 09, 2008 09:57pm | #23
          That's the Uponor system. I love it. Easier to make connections in tight quarters. And it's practically foolproof.
          No, I don't think the PEX will loosen up with time.
          Mike HennessyPittsburgh, PA
          1. Henley | Dec 10, 2008 02:51am | #24
            I have to say the warranty doesn't inspire confidence.
            Edited 12/9/2008 6:51 pm ET by Henley
            File format
      2. plumbbill | Dec 09, 2008 07:43pm | #19
        That's Propress¯ & we use it quite a bit, I have the same concerns about those as well.
        You are also correct about the removal part, Propress is a one time deal. If they freeze they will usually push the fittings off the pipe. That creates a repair nightmare.
        We use a lot of Victaulic on heating systems that relies on a rubber gasket, but like ductile MJ's the rubber is quite thick so that does give it more longevity.
  8. yojimbo2 | Dec 12, 2008 03:25am | #25
    hey in response to all the skeptics re: the shark bite fittings:
    (one of the great things about this site is that you learn so much from all the give and take)
    "Dear Pete,
    Thank you for your email and your interest in SharkBite
    Fittings. I am going to try to answer your questions as quick and
    direct as possible in an effort not to confuse issues as your internet
    forum has stated to do.
    * Plumbing codes require all products to be "Third-Party Listed".
    This means an independent agency tests the product to the appropriate
    Code and Standard, and also inspects the manufacturing location annually
    to see that the plant is following Quality Assurance procedures.
    Attached you will find our listing certificate from IAPMO. You can find
    this on their website as well.
    * Plumbing codes vary across the country, but none strictly
    prohibit the use of these fittings.
    * Our fittings are suited for domestic plumbing and heating
    applications and are warranted against defects for 30 years.
    * The cost effectiveness of these fittings is directly related to
    how much your labor rate is and how much you will have to invest in
    tools to install PEX with the other systems. (Even a DIY'ers time is
    worth something).
    If you read and follow our installations instructions (go to
    http://www.cashacme.com for a copy), you should have no problems using our
    fittings in your application. Bill Chapman"
    1. Henley | Dec 12, 2008 03:37am | #26
      It's that 30 year part I'm not comfortable with. Plus, if understand the warranty correctly they are only
      liable for the cost of the material.
        mmoogie | Dec 12, 2008 06:46am | #27
        I'll learn ya how to sweat copper if you really want ;-)
        1. Henley | Dec 12, 2008 02:45pm | #28
          Always grateful of good instruction;) Coming into plumbing this late in the game, I'd wager
          copper isn't a major concern for future Chuck.
Picture-Perfect Pergola
