I’ve been searching and have gotten mixed results. Are there sharkbite fittings available to connect to galvanized?
The majority of my supply lines have been converted to copper, but I’ve still got some hard to get to sections of galvy left which includes a tee that has started to leak. Pex would make my life easier if I could connect it to cut galvy rather than using a threaded fitting.
Don't know, but doubt it.
Here is your bumpity bump tho'.
"If Brains was lard, you couldn't grease much of a pan"
Jed Clampitt
I'm going to go out on a limb and say no.
The reason I don't think so - I don't think it can be done with galvy, black pipe, or any similar variation that requires pressure and longevity. Pipes that end in thread have the precision engineering in the thread itself. The actual diameters of the pipe matter very little compared to the precise angle of the cut threads. This is why there is so much variation on the outside and inside of the steel pipe - it doesn't have to be any other way. Those pipes will also have a seam on them. The glavination process will also introduce alot of surface variation.
I could envision something to do what you want, but I doubt it would actually be made.
Tu stultus es
Also a CRX fanatic!
Look, just send me to my drawer. This whole talking-to-you thing is like double punishment.
My thoughts too, but I was too lazy to type all that.
I use automotive heater hose and clamps in situations like that. Not for a customer, but fine for me.Spheramid Enterprises Architectural Woodworks
for what it's worth I was curious enough to email them and ask.
I'll let ya know what they say.
Buck Construction
Artistry In Carpentry
Pittsburgh Pa
Duh - never thought of that. Thanks.http://www.quittintime.com/ View Image
email came back as undeliverable!
I used the addy provided at the sharkbite site.
oh well ... back to square one.
Jeff Buck Construction
Pittsburgh Pa
They make brass PEX-to-NPT fittings, so you could cut and thread two legs of the pipes connected by the tee and un-thread the least damaged one.
(http://www.ardipex.com/pex-fittings.php)
Could it be that the tee is leaking because of galvanic corrosion due to copper connected to galvanized pipe?
If you haven't already done so, I'd change out the galv-cu connections for dielectric unions to prevent further galvanic corrosion.
Yeah - I know I could do that, but I can get further up into the wall if I could connect to other than a threaded end. I have plans to redo the baths in the next year or two, so I was trying to get rid of all but the last couple of feet of galvy in the wall behind tile I'm not willing to demo yet.
Almost certain it is. Won't be much of a problem if I can get rid of almost all of it, especially any connections.http://www.quittintime.com/ View Image
AFAIK pipe, of any type, is spec'd by the ID. And the OD will vary.Tubing is spec'd by the OD. That is why you use 5/8" compression fittings on 1/2 copper pipe.However, by design or accident, they made the OP of copper pipe, PEX and CPVC match so that things like sharkbites work. There is a line of PVC, sch 40 that does not match up.I doubt that the OD, which is sealing edge, will match up and probably not smooth enough.About 5-7 years ago I had a similar problem. What I did was use a steel compression repair coupling like this.http://tinyurl.com/dncrgsOn the one side was the cut galy. On the other side I used 6" brass nipple, threaded on one end (probably used a stock one threaded on both). I wanted the brass as it was strong enough to not collapse from the compression fitting. Also it is a good intermediate on the electrical scale (galvanic chart). Then a copper MPT to solder adapter.Held ever since..
Pipe is OD. Wall thickness changes with schedule.
You are right. I and I knew that. .
"Almost certain it is. Won't be much of a problem if I can get rid of almost all of it, especially any connections."Galvanic corrosion will be accelerated when the ratio of copper to steel increases. It would be good to isolate the cu-galv connections ASAP, since the only remaining galvanized is in locations where you can't reach.Good luck.
BruceT
Why not use a union fitting at that joint, come out of that with copper, and then use the shark bite?
