A customer has a fixed skylight in their roof in which the glass has completely shattered but remains intact within the frame. I believe it’s a VELUXE unit(approx. 11 yrs. old). Does the entire unit need to be replaced or can just the glass be purchased and re installed? Is the glass mounted in a frame that can be removed? I want to avoid disturbing the asphalt shingles if at all possible. What are the key measurements I should take while up on the roof to get replacement items? There are screws on the face of the unit which I assume are to attach the flashing kit pieces. I’m afraid that I may cause the broken glass to fall out if I try to remove anything. Ideally I’d remove and replace at the same time so the skylight opening isn’t exposed to the weather longer than necessary. Experienced advice greatly appreciated. Thanks.
get all the glass measurements, and look inside the alum. spacer for the code numbers etched into the alm . spacer bbetween the glass....
find the moadel number on the mfr.s id tag, usually on the frame, take any other meas. like the inside of frame hoiz. and vert...
examine the flashings. for damage..
go to your Veluxe dealer, and have them order you a new repalcement glazing, and the TAPE KIT for the glazing, and a new flashing kit if the old one is damaged...
when it comes in, read the directions and follow them...the mfr's rep, can also help you out...
go to a real lumber yard / millwork dealer to do this....you know, where you're a real peson instead of a number....they're in business for service.. and don't forget it when you think you're going to save some money at the big box....
*The Velux seems to be nicely designed. Just say no to leaks! The glass stayed together ... so i guess laminated glass works?
*Jim, follow Mike's instructions to the letter. I've replaced a couple of storm-damaged Velux glazing panels, and there's no problem re-establishing the factory-quality seal. Velux does offer several glazing options (low-e, etc.), so if you have a matching skylight in the same area, you'll need to match the new glazing to it. Again, a building supply professional is the person to talk to.Good luck, Steve
Mike,is the model # i.d. tag visible from the outside and do I need to remove the flashing pieces to see it? This skylight is 21/2 stories over an open foyer. I'm afraid of the glass letting go as soon as I start working on it. Also,because the glass is so spiderwebbed with cracks, it's difficult to see the alum. spacer strip. Is it marked in one or several locations?
you should be able to see most of what you want from the roof... or identify it by measurements.. operatiing crank ( or other details) take a picture or two if in doubt.. this is where a digital camera becomes valuable..
also.. the tempered glass (it is probable NOT laminated) is pretty strong,, but some of its strength comes from being an insulated unit.. and with the exterior galzing gone.. you now have a one inch fish tank instead of a skylight.. so take some 6 mil poly up with you and fold it with hospital corners over the top of the skylight and duct tape it in place to give some temporaray protection to the unit....
make sure you get paid for doing all this....
Thanks for all the input.I knew I'd find what I needed here.
Actually, they come both ways, window smartie. :) (I'm looking for one, and do think extra money for better insulation is esp. worthwhile in a skylight.)
Hey Jim, you might want to offer a glazing upgrade if they don't already have it.
A customer has a fixed skylight in their roof in which the glass has completely shattered but remains intact within the frame. I believe it's a VELUXE unit(approx. 11 yrs. old). Does the entire unit need to be replaced or can just the glass be purchased and re installed? Is the glass mounted in a frame that can be removed? I want to avoid disturbing the asphalt shingles if at all possible. What are the key measurements I should take while up on the roof to get replacement items? There are screws on the face of the unit which I assume are to attach the flashing kit pieces. I'm afraid that I may cause the broken glass to fall out if I try to remove anything. Ideally I'd remove and replace at the same time so the skylight opening isn't exposed to the weather longer than necessary. Experienced advice greatly appreciated. Thanks.
