— SHED DORMER construction
newbuilder | Posted in Construction Techniques on March 16, 2005 03:07am
I’ve been snooping around online and have been surprised to see so little of any value on ‘shed-dormer construction’.   Does anyone here have any suggestions for where to find any sort of guide or illustrated material related to this topic for a builder with too much confidence and barely enough experience?  ANY help much appreciated!
thanks!
Terry in Seattle
  1. woodguy99 | Mar 16, 2005 04:25am | #1
    Terry, there have been articles in the last couple of years in both FHB and JLC on various ways to build a shed dormer.  Architectural Graphic Standards http://www.amazon.com/exec/obidos/ASIN/0471241091/qid=1110939878/sr=2-2/ref=pd_bbs_b_2_2/103-1195175-2566223, and I'm sure many general framing books, show ways to frame one.  If you post specific questions maybe we can help?
    Mike
    1. newbuilder | Mar 16, 2005 11:46am | #2
      Thanks Mike,
      That book costs 225 bucks!!!  I'll look around some more ... just surprised that there seems to be no real quality material anywhere on the web that addresses the question ... first thing I've found that is not treated quite brilliantly on one site or another.  Anyway .. I'll keep poking around.
      Thanks again,
      Terry
        slimjim | Mar 16, 2005 01:48pm | #3
        Well, just slide over to the Taunton bookstore....the mag has done a bunch of shed dormer articles. Try back issue search or they are probably all together in one of their framing books.
  2. manimal | Mar 16, 2005 09:06pm | #4
    you would be surpised what you can find at a local librairy.
    1. newbuilder | Mar 17, 2005 12:52am | #5
      Cool.  Thanks (homer, manimal) .. I'll snoop around summore.
      Terry
      1. MikeSmith | Mar 17, 2005 01:22am | #6
        terry .. here's a photo essay i did last year...
        http://forums.taunton.com/tp-breaktime/messages?msg=39120.1
      2. Frankie | Mar 17, 2005 01:25am | #7
        HD has a few books showing house framing/ construction techniques. They are paperbacks and go for about $20 - $30 each. Some are even published by the fine folks at Taunton.Titles are something like Framing Construction Illustrated and Wood Framing - Tips and Techniques.F
  3. jimkidd2 | Mar 17, 2005 03:33am | #8
    Terry,
    Issue 158 has a really good article by Nick Pitz, a builder out of Philly.
    Jim
    "I want a good clean fight. No head butts, no rabbit punches, and no hitting below the belt. Break when I say break, and protect yourself at all times."
    1. newbuilder | Mar 17, 2005 04:58am | #9
      Thanks for more good info guys.  Nice work Mike!
      Terry
      1. johnharkins | Mar 17, 2005 10:22am | #10
        one of our bretheren here Mr Huler from up Port Orchard way had a nice one in a thread a couple months back
    Mongo | Mar 17, 2005 04:09pm | #11
    For a framing pictoral:
    Graphic Guide to Frame Construction by Rob Thallon.
    Lots of line drawings and flashing details, etc.
    1. newbuilder | Mar 17, 2005 11:41pm | #12
      Is that a retrofit, as I'm heading into?  Or is it how to frame a dormer into a new roof as your constructing it?  Big diff for me ... I need 'how to break open an old roof and install a shed-dormer'.
      thanks,
      Terry
        Mongo | Mar 18, 2005 01:17am | #13
        If you're looking for a "Step 1: Set up ladder" type of how-to-do-it, then no, it's not that type of book.
        It's a framing pictoral book with 200+ pages of framing details. From footings/foundation/rebar to roofline.
        It may not be the best book for you if you're looking for a bit more hand-holding along the way. Not meant as an insult.
        Still, it's an excellent book.
        1. newbuilder | Mar 18, 2005 11:17am | #19
          If you're looking for a "Step 1: Set up ladder" type of how-to-do-it, then no, it's not that type of book.   It's a framing pictoral book with 200+ pages of framing details. From footings/foundation/rebar to roofline.   It may not be the best book for you if you're looking for a bit more hand-holding along the way. Not meant as an insult. Still, it's an excellent book.
          I'm definitely not looking for a "Step 1: Set up ladder type of how-to..."    But I DID state clearly that I was looking for 'a guide or illustrated material related to framing-in a retro-fitted shed dormer'.  You then recommended the Thallon book "for a framing pictorial... with lots of detail, etc.".  My question in response was simply, 'does that cover a shed dormer retro-fit? ... or new roof construction?'.  Your response did not address my question.
          I do see, as you state, that it is a "framing pictorial book with 200+ pages and framing details from footings.foundation/rebar to roofline" ... but as a matter of fact it has nothing related to dormer framing in it.  The word 'dormer' does not even appear in the book.  (not in the '91 edition at any rate).  It's not 'hand-holding' I'm looking for -- it is, as stated,  clear details.  Thallon's book contains none... related to shed-dormers.  But yes, otherwise, an excellent book.
          Not meant as an insult either -
          Terry
            Mongo | Mar 18, 2005 05:26pm | #23
            "I do see, as you state, that it is a "framing pictorial book with 200+ pages and framing details from footings.foundation/rebar to roofline" ... but as a matter of fact it has nothing related to dormer framing in it.  The word 'dormer' does not even appear in the book.  (not in the '91 edition at any rate).  It's not 'hand-holding' I'm looking for -- it is, as stated,  clear details.  Thallon's book contains none... related to shed-dormers.  But yes, otherwise, an excellent book."
            I pulled my copy of Thallon's book ('91 edition) off the shelf. While limited, it does reference dormers and framed roof openings (chimneys, skylights, etc).
            A quick thumb-through of the pages:
            The framing schematic on p. 121 refers you to detail drawings on pp. 126, 133, 135, and 141.
            Add'l framing drawing on p. 127.
            Dormer details if using I-rafters on pp. 143 and 144.
            Flashing a dormer? See p. 157, tha shows an overview with references to drawings on pp. 161-163.
            Very limited gutters/downspouts dormer details? P. 183.
            Limited coverage? Yes. It's limited in that it requires a bit of intuition to translate the pictures into "how to" reality. You'l get no argument from me n that point.
            Personally, I like the book. I consider it an asset for the detailed drawings, and it shows the differences in methods or techniques. On that same point, I realize it's not the proper book for everyone.
            So, I fall on the sword. You are correct in that it does not enough clear details for you, and you are also correct, it was improper of me to offer it up as a reference as it doesn't fulfill your needs.
            "Not meant as an insult either -"
            None taken.
          2. newbuilder | Mar 19, 2005 02:47am | #24
            Thanks Mongo ... thanks homer...
            I truly appreciate the responses.
            Terry
          slimjim | Mar 18, 2005 02:12pm | #22
          "Step one-set up ladder"  was funny as hell!
        Mongo | Mar 18, 2005 01:22am | #14
        JLC back in July 2002 had an article on a "pop top shed dormer", where the cut into the existing roof, hinged the cut at the peak, and essentially pivoted a section of the existing rof up to create the dormer roof.
        Sidewalls were filled in.
        An idea that would limit exposure to the weather, but it may be a bit ambitious.
        1. MikeSmith | Mar 18, 2005 02:07am | #15
          wasn't that blodgett's ?
          he was always a big one for pop-topsMike Smith Rhode Island : Design / Build / Repair / Restore
            Mongo | Mar 18, 2005 03:23am | #16
            Looked it up, this one was by Bob Dausman.
          2. MikeSmith | Mar 18, 2005 03:36am | #17
            i remeber jimbo showing us a photoessay of raising the center portion of his roof
             i think it's his  shopMike Smith Rhode Island : Design / Build / Repair / Restore
            Mongo | Mar 18, 2005 04:03am | #18
            I missed that.
        2. newbuilder | Mar 18, 2005 11:22am | #20
          I've heard of guys doing this.  The idea is to use the wood that's there by simply raising it up and not to bring in new.  But the guy that I knew that did this ... quite a few years ago, laughingly said that he'd NEVER do it that way again!  :]
          Aesthetically though, I do like the idea ... the conservation of materials.  But it seems like you could still use those boards somewhere else ... on the sides perhaps.  They are, of course, 'real' 2X4's ... which is kind of a kick.
          Thanks,
          Terry
            slimjim | Mar 18, 2005 02:09pm | #21
            Like 'twas said before, if you get in touch w/taunton, they will sell you all the shed dormer articles, (retrofit/new) you can shake a stick at. I remember at least three. You can even get them downloaded. Search the back issues for "retrofitting a shed dormer"
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Postwar Comeback
  • Natural Simplicity
