Shed footers
user-85230 | Posted in General Discussion on September 28, 2007 01:50am
I have a customer who is going to build or have delivered a 10×10 shed and wants me to put footers in. I live in Pennsylvania. How deep should pour and how wide should I make it? The shed is one story.
  1. brownbagg | Sep 28, 2007 01:56am | #1
    put a brick under each corner
    Haga su trabajo de fricken
    1. user-85230 | Sep 28, 2007 02:01am | #3
      Hard to sell a job that way. Customer is convinced it needs footers. He won't go for a brick under each corner. Though it is probably all it needs.
    popawheelie | Sep 28, 2007 02:00am | #2
    I started a patio cover off the side of my house. I went down to the building dept. and they gave me a handout for a patio cover. In my area (just above Denver) they recommend a pier footer under every 4x4 that is 10" across by at least 30" deep.
    that sounds about right but you might want to go a little deeper depending on how deep you frost line is where you live. you want to get below the frost line because it will lift the footers out of the ground.
    SamT | Sep 28, 2007 02:46am | #4
    You have to check with your AHJ to get a definitive answer. Generally, the depth is = to the hundred year frost line.
    Generally, the size depends on the farthest distance between rebars. Reinforcing steel should be covered with 3" of standard concrete or 2" of water resistant 'crete.
    SamT
Rescuing Old Hardware
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
