Shed roof leaking…
drsess | Posted in General Discussion on August 28, 2009 11:11am
I need help/suggestions…my galvinized metal shed roof is leaking arond the nails after a number of years…any suggestions on the most efficient way to stop the leaks…a dab of caulk around each nail?……it’s probably 20×24 feet and many leaks…thanks for your time and consideration…..Dave
    IMERC | Aug 28, 2009 11:15pm | #1
    are the nails lead heads or neopreme washered???
    WOW!!! What a Ride!
    1. frammer52 | Aug 28, 2009 11:22pm | #2
      I think he needs to pul and install Screws.  Should have been screws in the first place.  A lot easier to replace when the washers go bad!
        IMERC | Aug 28, 2009 11:23pm | #3
        that is were I was going..
        WOW!!! What a Ride!
        1. frammer52 | Aug 28, 2009 11:54pm | #6
          OK
            IMERC | Aug 29, 2009 01:44am | #8
            also wanted to know how long the leaking and if the tin was rusted from arounf the nails...
            WOW!!! What a Ride!
          2. junkhound | Aug 29, 2009 02:14am | #9
            Just a shed, right.
            dollop of fibered roof cement ...
            or old tuna fish cans underneath......
          3. seeyou | Aug 29, 2009 02:59am | #11
            Hopefully he can get a gross of tins of tuna. But what's he gonna do with all that tuna fish?copper p0rn
          4. frammer52 | Aug 29, 2009 03:09am | #12
            Eat it, silly!>G<
          5. seeyou | Aug 29, 2009 03:14am | #13
            All at once? Sounded like he had a bunch of leaks. Art's been saving his tuna cans since he was in 2nd grade, but I'm assuming the OP has to start from scratch.copper p0rn
          6. frammer52 | Aug 29, 2009 03:50am | #15
            We can all donate our excess, empty's!
          7. User avater
            Dinosaur | Aug 29, 2009 03:43am | #14
            Aha! Another proponent of the old 'Kings Point Gasket'!
            Dinosaur
          8. drsess | Aug 29, 2009 02:30am | #10
            ...no visible rust from the ground...
          9. User avater
            IMERC | Aug 29, 2009 05:17am | #16
            like Piffin said...
            gasketed screws...
            or use salmon cans... they're larger...
            WOW!!! What a Ride!
          10. Piffin | Aug 29, 2009 04:23pm | #17
            LOL, you can't inspect and diagnose roof problems from the ground.
          11. frammer52 | Aug 29, 2009 04:29pm | #18
            Oh come on, good pair of binoculars and I can spot all of your mistakes!>G<
      2. Piffin | Aug 28, 2009 11:39pm | #5
        Now that I think of it, if these have been leaking for a number of years, the wood around them might be punky enbough that nothing will hold snug and every little windgust will loosen it back up again.
        1. frammer52 | Aug 28, 2009 11:55pm | #7
          True
  2. Piffin | Aug 28, 2009 11:38pm | #4
    take the nails out and put in screws with a larger diameter and neoprene gaskets
