sheetrock over foam
| Posted in General Discussion on July 2, 2001 12:37pm
Have any of you put sheetrock over a high thickness of foam. this is going to have 2 inches of blue foam over 1/2 inch of foil faced foam over 2X6 framing lumber that has 6 inches of fiberglass. this is for a wall that tips in 3 ft and is 8 ft tall. also am putting sheetrock over 3/4 inch of foilfaced foam on the ceiling.
thanks
sam
  1. piffin_ | Jul 02, 2001 08:28am | #1
    Lots of Enerfoam to be gluing it all up.
    1. Lance_Moody | Jul 02, 2001 12:34pm | #2
      *Be aware that even though the expansion coefficient of the rigid foam board is fairly small, it still expands when heated. On a north wall this may not mean much, but on a hot south wall or roof this expansion can push the drywall subtly away from the framing into which the fasteners are anchored, leading to depressions and "nail pops."Exactly this occurred on a job I did even though the foam was insulated from the hottest roof temps by the R-19 batts in between the rafters exterior to the foam. In his book on drywall techniques Myron Ferguson recounts a similar experience, and like many others, now installs nailing strips over the foam and fastens the drywall to these. This effectively isolates the finish from effects caused by movement in the foam plane.
  2. samcoinc_ | Jul 02, 2001 12:37pm | #3
    thanks
    sam
Old House Air-Sealing Basics
