sheetrocking over plaster ceiling
woodpeckers | Posted in General Discussion on July 22, 2012 08:06am
the plaster ceiling in my large living room (20 x 26) has lots of cracks but is not sagging. it has wire lath and plaster thats is as hard as concrete. tear out is not an option. i want to laminate the ceiling with sheetrock, which thickness to you recommend and what type of fastener? i tried sheetrock screws  but i had to drill pilot holes, its like drilling into concrete. the ceiling height is only 8′. any advice is greatly appriciated.
  1. Piffin | Jul 22, 2012 08:14am | #1
    Attach strapping to the plaster using tapcons. Do it 16" oc.
    Then you can use 1/2" ceiling board
    1. woodpeckers | Jul 22, 2012 10:07am | #2
      By strapping do you mean 1x4?
      1. Piffin | Jul 27, 2012 08:28pm | #5
        yes, more or less
        1x4 furring works too
        here in new England, you can buy strapping cheaper which is 2-3/4" wide spruce.
        You could also use metal hat-track
    2. calvin | Jul 22, 2012 06:24pm | #3
      Paul
      Tapcons?
      Are you thinking this persons residential ceiling IS concrete?
      Surely it could be, but I doubt it.
      Worst case-use bugle headed cement board screws.   (I'd have to go out to the shop to make sure they're not knurled on the underside of the bugle-that'd tear up the paper)
      But tapcons?
      I don't think I've ever had a problem with reg. drywal screws going into a plaster ceiling.  That must be some scratch coat.
      1. Piffin | Jul 27, 2012 08:32pm | #6
        He did say "hard as
        He did say "hard as concrete"
        I have run into plaster like that, and more often with wire lathe. CMU srews might work too, but SR srews will be a waste of time in stuff like that.
        The tapcons have a larger thread that will grip well, which is important in a ceiling, IMO
  2. DanH | Jul 23, 2012 09:38pm | #4
    There is a sort of heavy-duity wallpaper that would be a good answer if the ceiling is basically smooth.  "Wall liner" is what I believe it's called.
    1. Piffin | Jul 27, 2012 08:36pm | #7
      Dan
      Liner works fine on walls, but with a failing ceiling as he desribes, it is generally pretty much a waste of time.
      I might use a FG clothe web and new plaster or DB skimcoat if it is solidly attached
Outdoor Lighting
