Shim pt wood on masonry concrete
LearningtoBuild2025 | Posted in Construction Techniques on January 29, 2025 11:16am
I searched the forum for this but want to ask again specifically.
We are going to need to shim a pt site-built girder (3-ply 2×10) that will rest on masonry cmu concrete/rebar filled block.  We haven’t built the girder yet but pretty sure it will need shimmed around 1/4″.
I understand that shims should be sized so that the girder has full bearing over the shim as opposed to sticking some tiny shims in there, and I have also read that the shim should not be wedge shaped.
Question is – what exactly should we use to shim? When I search for shims, everything I’m seeing sold as a shim is small.
I see a zillion pros/cons of wood vs steel.
We’re in NE Tennessee, can see pretty heavy rainfall and be a very humid environment. Moderate to heavy termite presence.
I’m concerned as I know moisture and wood expansion/shrinking will likely be an issue to some degree.  Often the PT wood available around here seems relatively wet.
Crawlspace will be closed, and conditioned eventually with a dehumidifier.
County requires IRC 2018.
Cedar shingles seem like they’d be the easiest to source and cut to exact bearing size needed??
Thank you for any input.
  1. designbing | Jan 29, 2025 11:37pm | #1
    Take some Azek and trim it down to 1/4" use that as the shim. The PVC will stand up to anything.
  2. calvin | Jan 30, 2025 08:48am | #2
    A steel beam supplier will have composite shims in varying thicknesses and sized for your column top.
