Shimming with plywood vs. shims
Kevin_D | Posted in Construction Techniques on January 31, 2011 01:59am
Hello All,
     I had a quick question. My inspector disliked that I shimmed with plywood and said, “It’s like shimming with drywall, it just crushes.”
Second story walls sit on 3/4″ tongue and groove and don’t compress it… They carry all the weight of the roof load too. Is he just wrong?
Thanks,
Kevin
  1. Kevin_D | Jan 31, 2011 08:41pm | #1
    I shimmed a couple things with plywood.
    For instance I used it on doorways headers instead of cripples, because my architect called for 4x12s. With the 4x12s cripples wouldn't fit.
    It does receive bearing weight.
    I just don't understand how 3/4" tongue and groove can carry walls+roof load and not compress, but he's worried about other plywood compressing.
    1. AVR | Feb 01, 2011 03:37pm | #4
      What's the distance from the top of the header to the top plate?  How many layers of plywood?  Must be pretty tight if he'd like shims instead of your plywood.  Your solution sounds reasonable to me if I'm picturing it correctly.
  2. DanH | Jan 31, 2011 09:29pm | #2
    A narrow piece of coarse plywood, especially if cut the wrong direction, might tend to squeeze out some of the inner plies.  Plus of course plywood can have voids.
    But one's gotta wonder what you're shimming that's so heavy (and you're shimming with such small pieces) that this is a concern.
    (I'm personally fond of the plastic shims.)
  3. Piffin | Jan 31, 2011 10:35pm | #3
    Unless he is comparing to meal shims for an exgtremem ;load, he is just plain full of BS. Ply wll handle a load better than a typical cedar shim. I can say this after dealing with dozens of old houses with either kind.
Fast, Accurate Wall Framing
