shingle overlap on hips
buffy | Posted in General Discussion on May 15, 2006 07:05am
for u Woofers what is the best way to shingle hips butt and cut field shingles or overlap and nail. OC pro 40
    Sphere | May 16, 2006 01:53am | #1
    Try it both ways , the answer will be obvious.
    Damm, I miss that stuff
  2. Danno | May 16, 2006 02:32am | #2
    We used to cut and then ran cap shingles up the edges like you'd do on a ridge.
  3. Piffin | May 16, 2006 04:03am | #3
    I let them hang over the hip, then chaulk a line and cut it with ahook knife
    1. buffy | May 18, 2006 04:28am | #4
      are u cutting down the c/l of the hip or leaving the overlay and then putting rige caps on?
      1. Piffin | May 19, 2006 01:44am | #8
        snap line and cut shingles off at centerline of hip
  4. maverick | May 18, 2006 04:59am | #5
    cut one side at the hip, overlap the other side. that way the sandwich does'nt get too deep.
    1. buffy | May 18, 2006 05:31am | #6
      just climbed down off the roof should of checked post  earlier  did a double over lap and like u said is a little thick
      1. maverick | May 18, 2006 05:56am | #7
        best case scenario, roof both sides of the hip at the same time and stagger the overlap. does'nt often happen though
