Shingle Ripper – Can’t break nails??
MikeK | Posted in General Discussion on June 29, 2005 07:05am
I’m replacing some of the cedar wall shingles on my home. I purchased a shingle ripper (flat bar with hooks to grab nails).
I have not had good luck breaking the nails. I’m hooking the bar over the nails and wacking the bar as hard as I can with a hammer. Nails tend to pull out and bend rather than break.
What am I doing wrong? Do I need to sharpen my shingle ripper hooks?
Mike K
Amateur Home Remodeler in Aurora, Illinois
  1. MikeSmith | Jun 29, 2005 07:44pm | #1
    mike ... a "shingle thief " is NOT meant to cut or break nails... it's meant to pull them out..
    so
     .. your's is working just fine
    1. MikeK | Jun 29, 2005 08:06pm | #2
      Thanks, Mike.
      Now I really feel stupid!Mike K
    2. MikeK | Jun 29, 2005 08:09pm | #3
      Mike,
      I got to thinking.
      Since the shingles are overlapped how do I get a shingle out from the one above without cutting the nail or damaging the shingle above?Mike K
        jonblakemore | Jun 29, 2005 08:41pm | #4
        Pull those out to.I like the Vaughan 20" flat bar for this type of work (HD has them). The extra length makes it very handy to get under a nail that is slightly proud and lever it out.
      2. MikeSmith | Jun 29, 2005 09:23pm | #5
        the "thief " is just for that purpose..
         usually you have to start about 30" above your bottom.. just rough break the course below.....
        then you carefully split the last course and pull the splinters down and out...
        slide the thief up and hook over the nail.. rap on the thief and the hook will pull the nails out .. of course if you are following an idiot.. who didn't nail the cedar shingles where they are suppose to be nailed.. ( one inch above the covering course butt & 1/2" in from each edge ).. it makes it harder.. staples are also harder to thief..
        the 2d and lower courses you simply clean strip.. relay your new shingles.. the last new course  , traditionally, you lay about 1/2" below it's final place.. drive the shingle nails as toes ( slanted up ).. then you drive the butt of the last shingle up and into it's final location.. the toe-nail straightens out as you drive the butt and the head of the nail winds up hidden by the butt above..
         Non-traditionally.. you can face-nail the last course with SS nails... i prefer the traditional method
        Edited 6/29/2005 7:35 pm ET by Mike Smith
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
